05-20-2011, 05:28 AM | #1 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
| JoNeS'N LCC Poison Dart build
OK, I ran out and bought myself an LCC Race Roller yesterday, so the fun shall begin tonight. Basic parts list: JoNeS'N Frogger V2.1 "The Poison Dart" chassis (in grey) LCC race roller Losi Xcelorin 13.5T brushless system HS-7940TH servo @ 7.4 volts CC BEC Not sure on wheels and tires yet, but probably going to go with some B.A.M. wheels again. Let the fun begin. Casey |
05-20-2011, 08:04 AM | #2 |
Rock Stacker Join Date: May 2011 Location: Lacey
This should be a good build. Looking forward to seeing what you do with this one. PS TY for the great contact in buying a PD for myself. Cant wait to see it! |
05-21-2011, 01:47 AM | #3 | |
I got the suspension mocked up, but not completed. Here is a shot where I plan to mount the trans, but need to shorten the front driveshaft a bit to make it fit here. And, if you look closely at the next couple shots, you can see the trans is pushed back due to the driveshaft. Also, this is a good starting point for my suspension. Now I just need to limit my front shocks to 3.5". NOTE: the lower links are not the frog legs yet as I have no Traxxas Rod ends. (Just ordered a bunch yesterday). I will change over to the frog legs when the rod ends arrive. More updates coming soon. Now, I need to dig into my Tamiya DF-03RA and pull out my Losi Xcelorin 13.5T system. Also, need to locate my HS-7940TH servo. It is getting there. Casey Last edited by KC_JoNeS; 05-21-2011 at 02:37 AM. | |
05-21-2011, 09:24 AM | #4 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
I like it Not sure on the rear link tho.. i would drill the chassis to drop the rear lowers on the chassis.. other than that it looks great Whats the lenght come in at? |
05-21-2011, 05:36 PM | #5 |
Rock Stacker Join Date: Dec 2009 Location: Everett
Coming along pretty good, cant wait to see more. those chassis look sweet!
05-21-2011, 05:44 PM | #6 |
In the last pic, in the background, what shocks and springs are you using on the finished ones? The springs look tiny. How do they hold up?
05-22-2011, 08:39 AM | #7 | |||
The length right now sits at 12" exactly, but I will fix that with the frog legs when my rod ends arrive. Quote:
Casey | |||
05-22-2011, 08:44 AM | #8 |
Got some more done today. shortened the front driveshaft by about 1/2" limited the front shocks by using fuel tubing inside (1/2") mounted the shocks upside down switched the shock rod ends to Axial ends pulled the motor, ESC, and BEC out of my Tamiya Subaru to put into this bad boy As you can see, the front upper links are horrible. I hate the way they mount to the axle. I will do something to fix that ASAP. Things left to do: mount the trans pull my HS-225 mini servo out of my other rig to be used as a dig servo rework the front upper links get my Revo ends in to work with my frog legs Reprogram the BEC to 7.4 volts Casey |
05-22-2011, 08:57 AM | #9 |
what spring rate and oil weight are you using with the traxxas big bores and mini t spings?
05-22-2011, 09:33 AM | #10 |
Man it's the best looking chassis for a lcc IMO It's always hard to tell from pics, have you considered running the links outside the chassis? It would likely bring them out to the stock width too. Cheers Dan |
05-22-2011, 09:39 AM | #11 | ||
Actually, I do plan to outboard the front uppers and make them a bit shorter...this should fix all the issues with them. I am waiting on some rod ends to show up, but I am confident I should have this done and running the way I want it by week's end. Casey | ||
05-22-2011, 09:57 AM | #12 |
cool thanks
05-22-2011, 10:22 AM | #13 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Hey Casey, This came as quite a shock. Very creative ! Just goes to show how universal you made this chassis. AWESOME ! |
05-23-2011, 09:32 AM | #14 |
Quarry Creeper Join Date: Feb 2011 Location: Center Point Ia
Hey Casey,,,,looks great. I haven't started mine yet, but I'm not following or seeing the issues your talking about with the front top links!! Can you explain a bit further. I got your frog legs with my kit, and I actually have a set of the big bore shocks with the mini springs that I planned on using with this. So buy using the big bores, I can forgo messing with limiting them to 3.5 inches, but is that just for the front? Will the big bores work on all 4 corners? I actually got a package of the traxxas rod ends, revo and jato, these are the ends needed to incorporate the frog legs into the build? Can't wait to get started on my build,,,,chassis really looks nice!!! Thanks Mike |
05-23-2011, 09:46 AM | #15 | |
Top links...they are mounted very low so there is very little vertical separation. I basically remove the upper links and try to fasten them a bit higher up...like on the plates. I will show pics later of the front. The movement is now perfect. Shocks...the chassis was designed to use a 3.5" shock up front, and a 4" shock out back. Now, you can use any combination of shocks to achieve this, and yes, you can use big bores at all 4 corners...but, just make sure to do what you can to get the front shocks to 3.5"-3.6" and the rears to 4". Frog legs...These are used to set the wheelbase. If you have Revo ends, you are nearly there. You will also have to find some 4mm set screws. You may need to get some Jato ends (The long ones) to get the wheel base the way you want it. I have not reached that point in my build yet, as I am still waiting for my Revo ends. Most of the questions you have about the build will be answered with this thread upon my further completion. Casey | |
05-23-2011, 12:01 PM | #16 |
Yes, I'm looking forward to updates on your build!! I actually do have both the revo rod ends and the longer Jato rod ends sitting on my work bench and all the 4mm set screws needed!!! I'm in the process of putting a set of the new Chaotic Crawler links on my xr10 which require both!! I hope to get my chassis built this week and get it mocked up soon. I will try and get some pics this time, have never done or posted a build before but this seems to be a good place to start!!! Thanks for the reply Mike |
05-24-2011, 12:23 AM | #17 |
OK, I made a bit more progress the last few hours. Here you can see how I drilled my front servo plate to be able to use a different type of front upper link setup. The movement is much better now, and there is no axle steer under compression. Now, onto other matters....it turns out this skidplate is not setup properly to use the Losi tranny. So, in order to mount it and not interfere with the lower link screws, you have to mount the tranny in reverse. This should not be an issue, and in fact puts the motor weight forward in the chassis. Casey |
05-24-2011, 12:25 AM | #18 |
Now, I am just waiting for my Revo rod ends and my SR300 RX. Once those arrive, I will be in business. Casey |
05-24-2011, 12:30 AM | #19 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
i'm liking where this is going, are you planning a low-cg dig servo mount to fit this chassis, or just mounting it on top of the trans? also, slick thinking on just mounting the links underneath on the servo mount. those axles need some scratches though!
05-24-2011, 12:46 AM | #20 | |
The axles will get some scratches soon enough. | |
