05-22-2011, 09:25 PM | #1 |
Newbie Join Date: Feb 2011 Location: Rochester Hills
| LNC front axle teardown/axle shaft removal guide?
So I snapped a CVD in my LNC today. The book that came with it shows exploded views of all the vehicle components with part numbers, but doesn't show how it comes apart. Now I know my way around a 1:1 axle, and this doesn't look much different, but just to be sure, is there someplace I can find how to pull just the broken shaft out, or how to dissasemble the front axle? Can I pull just the shaft out without disturbing the gear setup? And the kingpins, are they just pressed in, and what do you guys use to remove them? Thanks in advance for any help, I really hope I can just pull the shaft.
05-22-2011, 09:31 PM | #2 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
EDIT: They are located above and below the bearing on the face of the knuckle Last edited by highlandcrawler; 05-22-2011 at 09:32 PM. Reason: Info | |
