07-23-2011, 04:48 PM | #1 |
Rock Stacker Join Date: Feb 2005 Location: Mansfield
| Wiring a CC Mamba Max Pro 1 Cell
So I am putting a MM Pro 1 Cell in a comp crawler and want to confirm I am wiring this thing correctly. From my understanding of this ESC, it does not have an internal BEC so I will have to power everything from an external BEC. If I set the external BEC to 7.2 volts, will that be enough to power the SR300 receiver, HT7955TG and Hitec 645mg servo? On the RX the aux port is for the dig servo, the throttle port is for the ESC and I remove the red wire from the plug, The STR port is for the steering servo. Can I plug the BEC into the bind port? Does this sound right?
07-23-2011, 04:54 PM | #2 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
you may want to direct wire that external to the steering servo, (this would involve putting in 2 externals though...) i assume the 645 is the dig? if so, i'm not sure its rated to do 7.2v. and yes on plugging it into the bind port if the 645 is more capable than i think. thats the one problem i have with the one cell, if you have to use one servo at a hv rating and one at a normal 6v rating. if all else fails, call hitec and make sure. EDIT: or just set the external to 6v, or max 645 input voltage. |
07-23-2011, 05:44 PM | #3 | |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
07-23-2011, 05:47 PM | #4 |
with the bec set it to 6v since thats all the 645 and 7955 are rated for, at 7.2v they will likely both burn up sooner or later. on the esc leave the red wire in or it wont work iirc (only remove red wire on esc with an internal bec when using an external one) and yes you can put the bec in the bind/batt port on the rx
07-23-2011, 05:52 PM | #5 |
Thanks guys! I got it all figured out. Now it is time to figure out how to run all the wires.
07-25-2011, 10:56 PM | #6 | |
Rock Crawler Join Date: Oct 2010 Location: triad
