01-15-2012, 03:03 AM | #1 |
Rock Stacker Join Date: Mar 2011 Location: The Netherlands
| 3rd dig servo?
Today i fried my 3rd dig servo and have no idea how that happened. My epa's are set right and the linkage has very little slop. When i use a 2s pack all is good, but when i use 3s my dig servo fries. Mt BEC from casle is set to 6v and the internal BEC on my MMP is also set at 6V. I am all out of thoughts how this could happen. Anybody got this problem before? |
01-15-2012, 06:55 AM | #2 | |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
| Re: 3rd dig servo? Quote:
One BEC at a time, did you pull the red wire out of you ESC going to the RX | |
01-15-2012, 02:30 PM | #3 | |
It is so weird, it only happens after running a few packs. No binding, the hole for the digfork shaft works also smooth and the dig works properly. Maybe the amp draw from 2 servos is to much for the BEC?? | |
01-15-2012, 02:47 PM | #4 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
| Re: 3rd dig servo?
direct wire the steering servo to the external bec, then just run the esc bec to the receiver. no problems other than my old servo decided it wanted to lift a solder pad off the board.
01-17-2012, 08:36 AM | #5 |
| Re: 3rd dig servo? |
01-17-2012, 12:22 PM | #6 |
| Re: 3rd dig servo?
i also ran into something when i was giving mine the once over. make sure that the servo horn is exactly centered when you put it on. mine was a touch off and cause the servo to fight just a bit.
3rd dig servo? - Similar Threads | ||||
winch AND dig off of 3rd channel? | 72Blazer | Electronics | 6 | 05-14-2009 06:28 PM |
Is the JR Z-1 radio 3rd ch adjustable for dig | Dogfish | Electronics | 6 | 02-27-2009 05:56 PM |
M11 3rd channel dig | revoracer99 | Electronics | 4 | 09-21-2008 10:28 PM |
