Waggaclint's LCC Well after deciding to get another sportman, I decided id like to give a Losi a go & i found that Zeko was selling his very well built Losi, so it was hard to say no, overall im very happy with the rig as its bean put together very nicely (big thanks to Zeko"thumbsup") Ive got a few plans in mind to make it as they say (my own rig) & im looking forward to knocking of some Axial based rigs as im the only one over in Perth that will be running Losi:mrgreen: Ill be running it this Sunday Comp so fingers crossed its debut will all go good. http://imageshack.us/a/img402/7186/dsc01452p.jpg http://imageshack.us/a/img835/3203/d...psdf1827c4.jpg Specs- Y Town Crawler CF wheels, Running Losi Boss claw tyres (ill be changing tyres shortly) 4" traxxas big bore shocks with losi mini-t springs Standard Chassis with cf shock towers MIP driveshaft upfront and LNC in the rear Gunnar body posts BWD rear link mount Lunsford ti links Custom made CF servo/batt mount Alloy Screws were possible Tekin RS with 13.5T redline (14mm Hi-Torque Rotor fitted) on 3s lipos Decased electrics CCBEC Hitec 7950TH Losi Alloy Front Spindles and Losi 20deg front hubs Losi Heavy Duty worms in the front Losi night crawler trans with reverse mount mod Dlux Knuckle weights Axial Hardline and Losi Grappler bodies Also Planning on gettn a new CF Chassis some time later in the year |
Re: Waggaclint's LCC Ahh so your the lucky bugger who got Zeke's sportsman. Nice car, well built and looks awesome. Ow and don't worry about those ax10 runners they just don't realise how cool the worm life is. 8):lmao:. Good luck at the comp colgouts truck is looking pretty beast lately. |
Re: Waggaclint's LCC Cheers Pajey, yeah colgouts rig is a nice bit of kit... |
Re: Waggaclint's LCC This is my 1st eva Losi as ive only run Axial based rigs before so its a bit differant i must say.. Anyway I got to run it yesterday for the 1st time & overall i was reasonably happy with it and came in around mid field (5th overall)for the Day.. For some reason i broke both rear lower link rod ends :doh: not sure why as i cant see any binding etc but no biggy, the biggest downfall is the steering (but hopefully soon ill have a fix for this with ghtpdm5 about to release his new setup) also id like a bit more punch/wheelspeed so i might look into gettn the Tekin 14.0mm rotor and see how that goes.. Also after running the last course of the day Highlucks worked out i was running my wheels wrong way round (backs on Front) so hopefully swapping them around will also help a little.. But overall i was pretty happy and hopefully me and the rig can only get better for the rest of season touch wood :mrgreen: ill be keen to pick up the SuDu One CF Chassis soon as well.. I also swapped over the a Losi RTR Body and i have a new Grappler coming in mail so i can paint it up to my liking.. http://imageshack.us/a/img213/5696/dsc01454b.jpg Stay tuned for updates etc thoughout the year.. |
Re: Waggaclint's LCC I'm only guessing on the rear lower link failures, but it looks like you're using Lunsford 4mm links and Losi rod ends. The Losi ends are designed for 4-40 thread so need to be drilled out to fit the 4mm. Brings up a few possibilities: Maybe the ends have been weakened due to the drilling operation. Especially if the drilled hole came out too small, stressing the plastic. Or too big, thinning the wall. The "bent" links cause forces to pass thru the ends at a slight side angle instead of straight thru, which is more prone to snapping the end. If the problem persists, perhaps some custom links with robust Revo rod ends would be the fix. But I use the Lunsford / Losi combo too and am happy so far. On mine, the supplied drill bit for the ends was too large and the ends tended to pull off. Had to CA them. That's a nice purchase. He built that fairly recently, right? Short attention span?? :) |
Re: Waggaclint's LCC Quote:
And yeah the rig was a fairly new build, not sure why he sold it as he had 2 other rigs forsale as well (getting out of crawling all together i think?) but a Bonus for me:mrgreen: |
Sent from my GT-I9300 using Tapatalk 2 |
Re: Waggaclint's LCC Well i got my hands on a Tekin 13.5T and 14mm HI-Torque rotor (Thanks to Colgout"thumbsup" ) anyway fitted up the rotor and installed to motor etc this morning and i must im pretty happy with the result :mrgreen: Overall it has given me more wheel speed and more punch, which is what i was looking for & the low end is still very smooth as well.. Ive got a Hotwire lined up as well so if i ever need to i can fine tune it some more.. |
Re: Waggaclint's LCC Played around with my Hardline body a bit this morning and came up with this.. http://imageshack.us/a/img822/1184/dsc01466no.jpg |
So far they have tested well, I've got a comp coming up on the 21st so ill see how they hold up.. Ill re-measure my wheel base tomorrow and post it up.. |
Re: Waggaclint's LCC Yeah ya right hey"thumbsup", measured it up this morning and it was sitting at 319mm, so I removed the rod ends and ground a couple mm of them etc so now sitting at 316.5mm:mrgreen: |
Re: Waggaclint's LCC Did a bit of tuning etc this morning.. Swapped my chassis around so im now running the motor more forward and sitting on the LHS (i found the losi tends to want to lift the lhf so overall it should have a bit better balance now) also swap my drive shafts around so im now running the MIP up front & LNC shaft in the rear.. Ive also upped the pinion to a 18t to gain a little more wheel speed (should help a little with rollover recovery) http://imageshack.us/a/img843/2445/dsc01490bf.jpg http://imageshack.us/a/img812/4011/dsc01492ws.jpg Ive also got a TAG axle kit ready to fit up as well, hopefully ill have frontend done for the next comp on the 19th.. |
Re: Waggaclint's LCC Keep an eye on that LNC driveshaft. Since it has no slip-joint, minor changes to wheel travel or link length tend to bottom it out, or worse, let the T-pin get one end out of the slot. I've had that happen and also had the small pin shear at the CV end. I like them when they work, but... |
Re: Waggaclint's LCC Gave my rig test run this morning while scouting a new comp location, so i thought id take a few pics.. http://imageshack.us/a/img837/6970/dsc01510nr.jpg http://imageshack.us/a/img109/194/dsc01513l.jpg http://imageshack.us/a/img703/6209/dsc01511d.jpg |
Re: Waggaclint's LCC Looking good mate, if you ca put together a full day like you did on course two last round. You will be knocking axials off the podium left right and centre. "thumbsup" |
Re: Waggaclint's LCC Time for a update, Well I've just about got my new TAG front axle setup sorted just waiting on some retaining compound to turn up and I still have to make up a steering linkage and drill and tap a few holes, but she will be all ready to go at the next comp :mrgreen: http://imageshack.us/a/img507/1043/lmrn.jpg http://imageshack.us/a/img22/7350/kow0.jpg Im planning on getn some new tyres shortly (not sure on what type yet?) ive got set of TLR buggy wheels to mount them on to as well.. |
Re: Waggaclint's LCC Mmmm silver. Looks flash mate. New tyres? You still using the boss claws? I know a few people are running rover's in west oz. But I've been using some sedona's and they're going pretty good. |
