11-18-2013, 12:23 PM | #1 |
Quarry Creeper Join Date: Dec 2004 Location: Croydon, Surrey, UK
| Losi Transmission
Now Im thinking of using losi axles in my class 1 scaler and I know they have been used, Iv got a set on my comp crawler that im gonna use. In the scaler space is gonna be tight as usual so im wondering seeing as the comp crawler trans doesnt gear down, can i run direct drive from a 21t brushless to a 1:1 transfer case and do away with the comp crawler trans altogether?? |
11-19-2013, 06:47 PM | #2 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
| Re: Losi Transmission
I dont think a 21T will handle a direct drive set-up like that. Ive pondered a similar set-up, but think at the very least, your gonna want a 2:1 reduction t-case and a 4-pole sensored motor to pull it off(for a class 1). But I hav'nt done this yet...Even at 2:1, the worms will be spinning crazy fast. 50:1 FDR for stock worms, 42:1 if you go HD's. My experience for scalers has FDR in the 70:1 area give or take. This is with HD gears for durability... Another option ive looked at (For Class 1) is use an LNC tranny mounted under the hood to a divorced 1:1 t-case for interior clearance. The math i've done, given a 4.19" diameter tire, has me starting with a 22T pinion. this will put FDR with HD gears around 48:1 This is achieving similar results as a 2:1 T-Case, but gives you options to decrease pinion sizes if the motor is'nt happy. In which the "Volt Up, Gear Down" lessons apply! |
11-20-2013, 06:32 PM | #3 | |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: Losi Transmission Quote:
12-06-2013, 02:22 AM | #4 |
Rock Stacker Join Date: Nov 2013 Location: Australia
Mate im running a night crawler trans set up, i got rid of the losi stuff and fitted up Tamiya gears out of a TT-01 straight onto the pinion like a F1. I am running a 60 spur and a 25 pinion i think. Only downside is the AV pitch. Im looking at using a scx-10 rear axle with the scx-10 gear holder, using 32 pitch gears, looking at it i need to do some chopping and welding but in theory it should work.
12-06-2013, 06:47 AM | #5 |
As mentioned, the typical motor to driveshaft ratio is ~3:1.
Losi Transmission - Similar Threads | ||||
losi transmission | RootBreaker | Losi Micro-Rock Crawler | 6 | 09-15-2013 06:38 PM |
Losi Transmission | HiloDB1 | Team Losi Comp Crawler | 1 | 06-16-2009 12:32 PM |
