Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Night Crawler re-release.
Old 09-25-2015, 03:28 AM   #1
Default Night Crawler re-release.
Just saw this Night Crawler 2.0 on an Australian store site. It's not on Horizon Hobby? Has HD worms as standard and a new light bar. Interesting that it may mean parts availability might increase. Hope hot racing are watching, I want metal trans gears again.
suij is offline   Reply With Quote
Old 09-25-2015, 03:41 AM   #2
Default Re: Night Crawler re-release.
Did not see that come.......
Losi 1/10 Night Crawler 2.0 RTR, RC HOBBIES
http://www.modelflight.com.au/losi-1...r-2-0-rtr.html
JENS is offline   Reply With Quote
Old 09-25-2015, 04:24 AM   #3
It's neither listed nor mentioned on the Losi site, but looks really promising if this is something more than just a local Australian kit.
Olle P is offline   Reply With Quote
Old 09-25-2015, 05:08 AM   #4
Hell Yeah! That's good news! People already said i was crazy for starting a LNC project.
Thumbs up for Losi!
MaFoDes is offline   Reply With Quote
Old 09-25-2015, 07:12 AM   #5
Losi Night Crawler 2 0 RTR 1 10 4WD Rock Crawler | eBay
Pics 2 and 3 show the box and says horizon hobby on it.
I really hope we can get some metal trans gears, I may have to call hot racing again and see what they say about new 2.0.
84yoda is offline   Reply With Quote
Old 09-25-2015, 01:19 PM   #6
Start picking up that phone....
Old 09-25-2015, 01:21 PM   #7
Isn't that also the first time the T's of the motor is mentioned? Seemed to be a mystery in the past as i believe. The box says 35T
Old 09-25-2015, 06:56 PM   #8
Totally forgot to call hot racing today, ill have to call on monday.
The regular night crawler was labeled as a 55t motor but people opened up the can and found out it was really a 35t. So at least its label 35t this time. Looks like there using a different brand of 35t motor as well.
Old 09-27-2015, 06:14 AM   #9
That's great I just purchased a LNC about 3 weeks ago crap I would have waited if they make the hd gears now would be the time for me I have it apart replacing the links & some tranny parts.
Rolin Roc is offline   Reply With Quote
Old 09-28-2015, 02:45 AM   #10
V2 seems to have some ups relative to the older version, but also some question marks...
* New battery tray. Is this the LCC tray in use? If so it's an improvement but not the best.
* All HD worm drives. Not that much of an improvement to the "regular" worm drives. It's front overdrive that's the key to success.
* Blue underside lights removed ant roof light bar instead. Probably an improvement for night drives. You still want to see what's below and behind the truck though...
* New body paint job. Looks better, IMO.
* CVD instead of dog bones. Both versions have their distinct advantages. The LCC CVDs are okay, if that's what's being used for the V2, but the dog bones of NVC are more slender which is an advantage.
Old 09-29-2015, 01:58 PM   #11
Called hot racing again about the steel gears, no luck. He said its up to the manufacturer so unless the NC 2.0 blows up, we are out of luck forever.
What would be awesome if boomracing or another company got hot racing manufacturer of the steel gears and bought them and could make them for us.
Old 09-30-2015, 12:47 AM   #12
Why steel gears? Plastic gears is good to have as the sacrificial part of the drive train.
There are other ways to achieve the fly wheel effect of heavier gears, if that's the desired feature.
Old 09-30-2015, 02:49 PM   #13
If you are strictly rock crawling, the plastic gears will suffice. However, when you start trailing with these vehicles, long distances, high speeds, etc. Such as the Scale Crawling and TTC style comps, then, Metal Gears become a MUST HAVE...unfortunately.
GiJoe is offline   Reply With Quote
Old 09-30-2015, 04:55 PM   #14
From what I'm told, higher kv brushless and 3s will eat the plastic gears either way. Whats why I want them and same with most people running brushless on the night crawler tranny.
Old 09-30-2015, 06:47 PM   #15
I run my scaler converted LNC on brushless (Tekin Redline/MMP) and have only gone through one set of plastic gears. I'd like metals, but at the cheap price I'll keep replacing the plastics for now. Atleast a rerelease means the replacements will stick around hopefully!
newmarketeod is offline   Reply With Quote
Old 09-30-2015, 07:20 PM   #16
How old is the night crawler?
Old 09-30-2015, 07:30 PM   #17
The problem with plastic is it will always fail, and yes there cheap and easy to replace but I'm pretty sure there's a limited supply (NC/CC parts) and will run out sooner then later. Lots of people run brushless on the night crawler trans and that will only go up in numbers, especially with the 2.0 released now too. Who knows, I could be wrong.
Old 09-30-2015, 07:32 PM   #18
I just bought 4 sets of gears I'm outa control !
Old 09-30-2015, 07:37 PM   #19
Not positive but I think 2009?
Old 09-30-2015, 07:42 PM   #20
Par for the course thought it was kinda new lol I have been out of electrics for about well since the jrxt not sorry that I bought it thou I like it I picked up all the links that were used on the LCC along with c hubs & rear carriers along with some HR parts for the tranny & a HS7955tg servo
I was running nitro got out of that & now into gas.
Night Crawler re-release. - Similar Threads
HPI's New Crawler King Release..... TrilloThrillo110 General Crawlers 6 11-06-2014 11:44 AM
Difference in AX10, Night Crawler, and Comp Crawler final gear ratios? shelljeep Newbie General 11 02-05-2010 12:48 AM
losi rock crawler release date some87 Chit Chat 2 02-01-2009 11:31 AM
