02-03-2015, 02:23 PM | #1 |
Rock Stacker Join Date: Aug 2014 Location: So. Cal.
| HD worms or not?
How can you tell, visually, if you have HD worms or not? I bought a used rig, and I'm not sure.
02-03-2015, 02:57 PM | #2 |
| Re: HD worms or not?
Look at pictures or count teeth.
02-03-2015, 03:11 PM | #3 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
The HD spool will have 21 teeth. The stock spool has 25 teeth. You can tell which you have without taking it apart again by noting the number of driveshaft turns it takes to make the tire go one revolution. The spool advances one tooth for every turn of the driveshaft, so a HD worm set will require 21-turns to make the tire go one revolution. Jerry
02-03-2015, 04:36 PM | #4 |
You guys rock! Thanks! I'll check when I get home.
02-04-2015, 12:25 AM | #5 |
Just to add: The ideal setup is to have HD worm drive in the front axle and stock drive in the rear, so check both axles.
02-05-2015, 11:35 PM | #6 |
They're all standard, all four Losi axles I have, lol.
HD worms or not? - Similar Threads | ||||
Worms | Fish11 | Team Losi Comp Crawler | 25 | 04-17-2012 08:13 AM |
Worms | outkast7222 | Team Losi Comp Crawler | 5 | 07-25-2011 04:13 PM |
Worms? | Tklan Crawler | Team Losi Comp Crawler | 4 | 05-24-2010 06:00 AM |
the worms | asw27x | Team Losi Comp Crawler | 3 | 04-28-2010 03:33 PM |
worms | jeepcj776 | Team Losi Comp Crawler | 9 | 09-28-2009 06:12 PM |
