Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: rear shaft dimensions
Old 10-15-2015, 07:04 AM   #1
Default rear shaft dimensions
for a project I'm working on (winch using lcc spool/worm gear) I need to run a short shaft into the spool to drive my spindle. does anyone have dimensions on a standard lcc rear driveshaft? looking to find out the width (flat side to flat side) of the square tang that engages the spool and the diameter of the narrowed section of the shaft between the tang area and the outer bearing retainer. I'm guessing the shaft diameter is 5mm but I want to confirm.
any help is appreciated.
jebster is offline   Reply With Quote
Old 10-15-2015, 01:14 PM   #2
Default Re: rear shaft dimensions
Tang,-flat side to flat side: 4,5 mm
Narrowed section closest to tang: 4,5 mm
Outer shaft diameter,-where the bearing is: 5 mm
JENS is offline   Reply With Quote
Old 10-15-2015, 01:36 PM   #3
thanks for the info. and it looks like I have to find something custom made. with the narrowed section being 4.5mm it won't work for me (needed that to be 5mm).
rear shaft dimensions - Similar Threads
Rear shaft options ash38 Axial Yeti 24 10-15-2014 04:13 PM
Rear axle shaft natskiboy Axial SCX-10 1 04-19-2014 10:05 PM
Hilux rear cab dimensions jeepscx10 Paint and Body 0 02-04-2014 09:32 PM
Rear axle shaft? LUNAticCrawlingCrew EnRoute Berg 3 08-01-2011 12:35 PM
Busted the rear shaft highroller Newbie General 7 02-14-2010 09:05 AM
