01-08-2016, 05:07 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Vienna, Austria
| LCC Tranny Conversion to "real" DIG ??
Hi, I would want to run a LOSI LCC Transmission with AXIAL axles - and a low KV Motor. But as it is the DIG is in reality a free spool - because the Worm axles are self locking. So any of you Losi Masters heared of a conversion to make it work like a real DIG? Thank you for your help! Daniel |
01-09-2016, 11:55 AM | #2 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: LCC Tranny Conversion to "real" DIG ??
The problem you are going to run into is the gear ratio will be way to high for the dig to function well. You will also only be about 10:1 instead of the 40:1 that will work well.
01-09-2016, 11:59 AM | #3 |
12:1 would be perfect! My 500kv RoC412 worked perfect with this Ratio for RECON G6
01-10-2016, 12:35 AM | #4 |
Quarry Creeper Join Date: Apr 2011 Location: Estonia, Europe
There isn't such mod to use the LCC tranny with Axial axles. For the DIG function the drive is disconnected and the worm drive locks itself. With Axial axles it would work FWD / 4WD / RWD
LCC Tranny Conversion to "real" DIG ?? - Similar Threads | ||||
The ultra compact driveshaft " Real Constant Velocity " | maduff | Tools, and Procedures | 15 | 01-17-2015 09:36 PM |
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
the "REAL DEAL" toyota Tacoma hard cab. | AxialJeepster | 1.9 Scale Rigs | 4 | 01-13-2013 03:11 PM |
"dig" + "twist torque control system" | tentmaker7 | Videos! | 9 | 05-29-2008 01:18 AM |
