Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Suij gets his Losi unstuck.
Old 08-15-2016, 09:32 PM   #1
Default Suij gets his Losi unstuck.
I got my hands on an Unstuck chassis from Krazed Builds so thought I should document my Losi's rebirth.
I'm not really good at keeping a build thread going but will post what I've got.
Chassis: Krazed builds Unstuck.
Esc: Mamba Max Pro
Motor: Hobbyking 17.5t
Servo: Savox 1270tg
Axles: Losi Comp crawler with HD gears I the front standard in the rear.
Shocks: Scx10 on the front some others I had laying around I the rear.
Home made links and electronics plates.
Where the stance sits now.
Home brew electronics plates.
It's now all wired up ready for testing and tuning.
suij is offline   Reply With Quote
Old 08-15-2016, 11:10 PM   #2
Default Re: Suij gets his Losi unstuck.
Just a quick couple of photos of how it sits now ready to run.
Old 08-16-2016, 05:19 AM   #3
Custom Carbon Fiber
Robbob's Avatar
Looks good!
Keep us posted on how the truck does for ya
Robbob is offline   Reply With Quote
Old 10-04-2016, 06:10 PM   #4
Got the rig out for a round of our local comp series. The car drove really well considering I forgot to plug in the sensor cable. The chassis was outperforming my driving all day. Without the low rpm cogging it should be a force to be reckoned with I hope. I did some of my best driving and my 10 year old son drove it in the comp as well. He actually ended up placing ahead of me at the end of the day. Guess I'd better start building him a sporty of his own or stop giving him advice on course lol.
Old 12-29-2016, 09:05 PM   #5
Found a bit of spare time at work the other day and turned up some TAG style adaptors for the rig. Still need to get hold of some XR10 axles and wraith knuckles but better steering is coming my way.
Old 12-31-2016, 08:19 PM   #6
Great looking build.
I am starting on my losi unstuck build. Really hope it turns out as nice as yours.
What weight shock oil are you running?
Sent from my SM-G900R4 using Tapatalk
doug.steele04 is offline   Reply With Quote
Old 01-17-2017, 03:55 AM   #7
Some small progress today, just waiting on my xr10 shafts and knuckles to make their way down to Oz.
Old 01-17-2017, 04:22 PM   #8
Do you make your own xr adapters?
Old 01-17-2017, 06:16 PM   #9
I made this set, but I don't have regular access to machines to make up more.
Old 01-17-2017, 06:32 PM   #10
CODYBOY's Avatar
Hey suij, looking very nice!!! Good luck with getting your parts.
Ernie
CODYBOY is offline   Reply With Quote
Old 01-17-2017, 08:12 PM   #11
Just got my LCC and you are giving me great ideas man. Keep it up brother!
Nastyman211 is offline   Reply With Quote
Old 01-31-2017, 11:45 PM   #12
Still waiting on my XR10 shafts to make it down to Australia, so fitted up some knuckle weights I whipped a while ago. Got about 55grams on each knuckle.
It was a magnificent day out today, so took her out for a test run. Car is driving really well but could probably do with a little more weight when I get a chance.
Old 03-21-2017, 02:15 AM   #13
So I have shelved my home made TAG style steering mod for now. I snapped up one of Codyboy's kits instead.
Since receiving the kit I have modded the uni's for a bit more steering without binding and started to build up the axle using plastic XR10 knuckles and C hubs for now.
I found the standard XR10 setup wasn't giving much more steering angle than Losi CVDs so I made up some new carbon fibre steering arms from an old servo mount I had in the spares box.
I nave made up a new servo and electronics plate from aluminium and have some temporary steering links set up until I get myself some more rod to make the final ones.
Next will be installing the electrics and fitting it to the car.
Old 03-23-2017, 10:54 PM   #14
I wasn't happy with the servo location in the above setup, so went back to the drawing board and came up with this.
This has moved the servo lower and also gives it some protection. I have also moved the tie rod behind the axle. This setup seems pretty good in the driveway. I still need to clearance the universals some more, but think I will disassemble them to do that.
Old 03-23-2017, 11:35 PM   #15
MODERATOR™
EeePee's Avatar
Seems way wide. I understand why but isn't that really wide? Track width I mean.
EeePee is offline   Reply With Quote
Old 03-24-2017, 12:21 AM   #16
It is a bit wide at 11 1/2", but I need to get some smaller hubs. I only had 750's on hand. Thinking shift hubs may be in my future.
Old 03-24-2017, 09:34 AM   #17
CODYBOY's Avatar
Looking good suij, if you can get it down to about 10 1/2" you will be perfect. Thanks for sharing your build with us!
Ernie
Old 05-05-2017, 05:04 AM   #18
I made some progress with the parts I made for a TAG style xr10 conversion for a sporty for my son.
Just need some electronics for it and I can start building it up for him.
Old 05-05-2017, 08:10 PM   #19
CODYBOY's Avatar
Looking good, a nice start to your sons rig. Glad to see your using your home brew tag axle. You did a really nice job on it, Be sure and keep us posted on your progress.
Ernie
Suij gets his Losi unstuck. - Similar Threads
Another UnStuck is born kmnss Axial AX-10 Scorpion 28 12-30-2016 10:04 AM
I'm Unstuck by RC! ROCKCRUISER Axial AX-10 Scorpion 13 07-06-2016 03:08 AM
Suij is trying a Losi scaler. suij Team Losi Comp Crawler 9 11-30-2015 07:29 PM
