11-18-2008, 10:21 AM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: Temecula
| Kreation Station Test The Kreation Station© Assemble, Weld, Cut, Notch, and layout, in one area! Work in ONE spot, not in multiple locations! • Perfect for hobby RC, and production builders alike. • Go from concept to completion in one spot. • Small enough to be moved easily. • Large enough to build almost any 1/10 scale vehicle. • Many upgradeable accesories. __________________________________________________ ________ The Ratchet Bender: Qty:1 • Designed for flat “Layout Style” bending. • Works with a standard 3/8” Ratchet. • Bending is more comfortable since you can move the ratchet to any position you choose. • The Ratchet Bender has a counter bored 8/32 hole to allow fastening the Hex dies directly to the lever. • The unique “Hex Head” dies are extremely strong and easily interchangeable for quick diameter changes. • Comes with two 1/4” (.25X.31 & .25X.3 diameter “hex” dies, and two (.125X.31 & .125X.3, 1/8” “hex” dies. (All hex dies are threaded 8/32 for optional fastening). • The “Shoe Die” is adjustable via the knurled thumb screw, and allows perfect fitment to the material and correct pressure against the Hex dies. __________________________________________________ ________ The Multishoe: Qty: 3 • The “Multishoe” is 3 tools-in-1, Is serves as a material guide for the “Hex Die” and also as a “Jig” to set-up and/or weld round and flat material chassis. • Slotted to adjust to different radius dies. • Predrilled and countersunk allen hole for “Jig” use. (on sides) • “Square” milled on one side for flat metal chassis and “V” milled on the other for round metal chassis. also uses unique knurled thumb screw for quick adjustment and clamping. • Comes with six multishoe “Clamps”, three are “V” shaped, and three are “U” shaped __________________________________________________ ________ Swivel Table: (optional) Qty:1 • 1/4” aluminum plate 6”X6” • Two pre-drilled shoe locations for jig/welding work. __________________________________________________ ________ The Table: Qty:1 • 1/4” aluminum plate 18”X24” • Two Pre-drilled pin and shoe locations for flat and compound bends. • Pre-drilled for 4” swivel table • Pre-drilled for tubing notcher • Comes with 4” legs. __________________________________________________ ________ Tubing notcher: coming soon (optional) Qty:1 • Easily mounts to side of table with pre-drilled mounting holes. • Works with any standard Dremmel. • Allows for multi directional notching for 1/8”-1/4” material. • Includes 6/32” tap for custom fixture mounting locations. • One thumbscrew for unlocking/locking down the table. to allow for round or flat material. |
11-19-2008, 04:41 PM | #2 |
I wanna be Dave Join Date: Dec 2007 Location: Florida
I'd be glad to test that for ya...
11-19-2008, 04:53 PM | #3 |
RCC Addict Join Date: May 2008 Location: Green Bay
Sounds great !! Whats the price on this?
