02-22-2008, 07:23 AM | #1 |
Rock Stacker Join Date: Dec 2007 Location: california
| mudslingers
post pics if you got them and what wheels you're on. i'm lookin to get a set, but im worried about the offset provided with the wide wk axles. also, can someone post up a pic of slingers next to stock wk tires, i wanna see the size difference. |
02-22-2008, 12:59 PM | #2 |
Pebble Pounder Join Date: Oct 2006 Location: rochester (detroit area)
1.9, 2.2's, clod or 40 series? or doesn't it matter? here are 40 series. |
02-23-2008, 09:47 PM | #3 |
Pebble Pounder Join Date: Sep 2007 Location: Kalamazoo
Here you go. first pic is 2.2 on Rc4wd bead lock small lugs removed next to WK stock tires and rim. second pic is 2.2 , WK, and stock T-maxx tires on proline wheels. hope it helps. |
02-23-2008, 10:21 PM | #4 |
Quarry Creeper Join Date: Jan 2008 Location: Eagle Mountain, Utah
what adapters do i need to run t-maxx wheels on my wheely king?
02-23-2008, 10:50 PM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
The ones that it comes with, Extra hexes in the box, 14mm hexes. Anyways I'm running the 2.2's on hacked apart stock WK wheels. Last edited by Mnster; 02-23-2008 at 10:55 PM. |
02-23-2008, 11:24 PM | #6 |
02-24-2008, 10:09 AM | #7 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
| classic
That chevy looks awesome and the tires look great on it. How do the actually WORK though, as compared to like your rock claws?
02-24-2008, 10:15 AM | #8 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
The Rock Claws are a comp tire. The Mudslingers are a scale tire. Rock Claws are better on rocks, Slingers better for mud, and the scale trails.
02-24-2008, 10:31 PM | #9 |
I wanna be Dave Join Date: Sep 2004
heres my crawler with some 2.2 slingers. they don't work all that well on rocks.everything else they work great on.(these are the old harder compound) |
02-25-2008, 09:17 PM | #10 |
| why not
what is the actual reason they dont work well is it the compound? Do they just spin on the rocks instead of grip them or what?
02-25-2008, 09:49 PM | #11 |
02-26-2008, 12:12 AM | #12 |
Rock Crawler Join Date: Apr 2007 Location: portland
I hear the soft slingers do good. But The bogger design was not meant for rocks. You can't expect them to be that great. Just like the 1:1's.
02-26-2008, 11:08 AM | #13 |
What are cutslingers? Do you have a pic?
02-26-2008, 11:33 AM | #14 |
02-26-2008, 01:51 PM | #15 |
Newbie Join Date: Feb 2008 Location: AK
02-26-2008, 01:53 PM | #16 |
Sorry for the post, i found that they're axial NARROWED wheels. Is this a correct statement? It would be nice to have more of a selection for these tires :( |
02-26-2008, 01:57 PM | #17 | |
edit: ha, you figured it out while i was replying. | |
02-26-2008, 02:39 PM | #18 |
Thanks a lot! Will standard tires fit the narrowed rims? Or would it be bad to switch tires once mounted on beadlocks? Thanks |
02-26-2008, 03:45 PM | #19 |
to my knowledge, the only tires made to fit the axials are the slingers and the moab XLs. switching tires should be easy - it's possible to strip a threaded hole out when taking screws out and putting them back in, but just be cautious when do so, i guess. when the 40 series rock crusher tires are available, i plan to swap the slingers out and keep 'em for mudding around. but the idea is to keep the axial wheels for both. as for a standard tire - i'm not sure. a regular 40 series tire would most likely need to be narrowed. otherwise most other tires aren't as tall and have less sidewall, compared to the slingers and moab XL's. |
02-26-2008, 03:54 PM | #20 |
Great Info! I wanted something great in the mud and provide the most ground clearance. Looks like i found the perfect setup!! |
