08-17-2008, 06:43 PM | #1 |
Rock Stacker Join Date: Jul 2008 Location: Under A Rock
| Losi Tires What Foams Are You Running?
I have searched,but can not get a straight answer.
08-17-2008, 07:00 PM | #2 |
Pro-Line memory foams in front. Using 6 oz. stick on lead. Hybridized Pro-Line memory foam sandwiched between two 1/4" slices of Pro-Line regular foam in the rear. 3 oz. stick on lead. |
08-17-2008, 11:42 PM | #3 |
Pebble Pounder Join Date: Jun 2008 Location: Kalispell
I don't run foam in my rock claws. Just a little air trapped in them in the house in front of the air conditioner. Then when I get outside in the sun the air expands to just the right pressure. I run 8 oz. in each front tire, nothing in the rear. They will outclimb my Panther Cougars w/memory foam in this setup. However, I pinched a sidewall at our last Comp and need to try some CA to patch it because it lost its airpressure. |
08-17-2008, 11:57 PM | #4 |
Moderator Join Date: Jul 2007 Location: Texas baby!
I would run a stock, uncut Losi foam in the rear and a http://www.tcscrawlers.com/8-Rockham...h-p-16846.html or http://www.tcscrawlers.com/8-Rockham...h-p-16844.html in the front. For weight start with none in the rear and a full strip wrapped around the front wheels. I would not recommend running without foams. |
08-18-2008, 12:02 AM | #5 | |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
X2..... I run the reds in front and the pinks (#5's) in the rear. Works pretty good, but I seriously think running the stock losi foam (uncut) works just as good if not better on some cases. 5oz in each front (Ericson comp heavies), and 3oz in the rears (standard Ericsons) is good start point for weight also.. | |
08-18-2008, 12:17 AM | #6 |
I run a regular foam in the rear to limit traction. Too much and the truck goes over backwards. The 3S lipo makes up for the loss of traction |
08-18-2008, 02:50 PM | #7 |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
In my claws I run Aces donuts mem's 6oz of weight up front and stock uncut 3oz of weight in the rear. performs great |
08-18-2008, 03:01 PM | #8 |
Pebble Pounder Join Date: May 2008 Location: Cottage Grove
I run 2 stage foams that i made with the stock losi foam on the outside and proline memory foam in the middle i cut them to the sizes that i thought would work the best then i used spray adhesive to bond them and they work great
08-18-2008, 09:39 PM | #9 |
Newbie Join Date: Aug 2008 Location: Bakersfield
| Did you happen to get any pics if the foams after you glued them up ?
08-18-2008, 10:33 PM | #10 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
I run stock uncut Losi foams in the rear and Proline firm buggy foam in the front. I have 3 9/16 bearings front and 1 9/16 and 1 3/8 in the rear on Mayhem double phattys. The shorter buggy foam gives the tires just the right bite.
