Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tires and Wheels
Thread: BFT assoc tire
Old 03-07-2004, 05:28 PM   #1
Colt Python/SR9c
TwistedCreations's Avatar
Default BFT assoc tire
well i just picked up a set and threw them on..havent ran them yet ( waiting on batteries to charge) but for the guys running them,are you running them with the inserts or not? i am wanting them to conform over the rocks but not really smash down like they are flat..or will the foams break in some after i run them?
also has anyone cut on the tires yet? have any pics of designs?
Jeremy
TwistedCreations is offline   Reply With Quote
Old 03-07-2004, 09:10 PM   #2
Default Re: BFT assoc tire
I run mine without, But I have only cut some of the middle tread portion. I think I need to cut some more tire off, once I get a chance to run on dry rock I will see.
MaxxZilla is offline   Reply With Quote
Old 03-08-2004, 09:24 AM   #3
Cut your foams!
Narrow them by about 3/4 inch.
Then, thin them out. Cut them so they are half as thick.
This will allow the tire to flex like there is no foam until the tire overflexes. Once that happens, the foam will control the overflex.
You can see how I cut my tread pattern on the Home page here. Look at the article regarding putting Big Tires on TXT wheels.
DirkDigler is offline   Reply With Quote
Old 03-09-2004, 05:41 AM   #4
Colt Python/SR9c
thanks dirk, i'll try that with the foams...i like the tread pattern ya got there. now all i need is some blinging bead locks like that
Old 03-10-2004, 03:02 PM   #5
can everyone spread the word that the bft's are the exact same tire as nitro quakes and the nitro quakes are a hell of alot cheeper
Ian
MOJOJOJO is offline   Reply With Quote
Old 03-10-2004, 03:05 PM   #6
NO NO NO!!!
They are NOT the same tire. They are the same design but not the same rubber compound. The Quake tires are much harder and do NOT make a good crawling tire. They are cheaper for a reason! Please! Do your homework before posting something like that. Imagine how many people would have gone out and gotten the Quake tires, only to find out they SUCK! They would all blame you!
Old 03-10-2004, 06:38 PM   #7
Ian
Have you lost your MoJo? Sorry I couldnt resist the Austin Powers humor but I agree with Dirk on that one.
shadow is offline   Reply With Quote
Old 03-11-2004, 12:15 AM   #8
sorry bout that but they seem to do great on mine but im not sure if thats cuz mine weighs like 20lbs
once again im sorry
Ian
Old 03-11-2004, 11:00 AM   #9
No worries Mojo.
On a heavier truck, they probably would work ok but I would still recommend the softer compound in any situation.
Old 03-12-2004, 10:44 PM   #10
yea if any of you are wondering i just posted my truck pics in the maxx forum
Ian
Old 03-14-2004, 08:53 AM   #11
Where can I get these tires?
Vu14TJ is offline   Reply With Quote
Old 03-18-2004, 05:49 PM   #12
Colt Python/SR9c
i got mine from my local hobby shop
here, towerhobbies has them also
http://www2.towerhobbies.com/cgi-bin...LXFUL6&P=7
Old 04-03-2004, 09:54 PM   #13
Will the BFT's fit on Clod wheels? Or, using the BFT wheels, would they fit onto clod axles?
Mazlem is offline   Reply With Quote
Old 04-05-2004, 10:01 AM   #14
They will fit on clod wheels but you have to do a little extra work to make them fit. Check out the home page to see the article on how to do it.
The BFT wheels will not fit on clod axles wtihout an adapter.
