Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Mayhem White Lightning Series
Old 01-11-2009, 02:21 PM   #1
Default Mayhem White Lightning Series
For a while now I've had a set of white Delrin wheels that Mayhem Engineering sent me to do some dying on. With work being hectic for the last several weeks I have not had time to get around to it. Sorry Dan
This is a really simple process just takes a little time and patience. This will give anybody a chance that wants the light weight features of Delrin and have some color options other than black.
I HIGHLY RECOMMEND DOING THIS OUTSIDE OR IN SHOP WHERE A LITTLE SPLASHING WILL NOT MATTER
First find a color or you can mix colors for different effects.
Color Chart
Then get about a 3qt boiler bring the water to a boil and add dye.
Drop the heat to a slow simmer
Use 1 or 2 beadlock screws to attach some tie-wire or something similar to the wheels.
Then dip the wheels fully submerged and hang the tie-wire over the side of the pot for easy access.
Heres where the patience takes place it may take a good while to get the shade you want since these wheels are really dense. The ones I just done took over an hour.
Finally when at the shade you want remove from boiler and rinse w/cold water and thoroughly dry them blowing out the bead and the screw holes to prevent a later mess.
Here's some pics of the wheels I just completed. Its a mixture of Scarlet & Wine colored dyes with just a hint of black. I'll use these on my Losi 1/10 when it arrives. Kinda hard to believe these started out bright white
TEDROCKZ is offline   Reply With Quote
Old 01-11-2009, 02:37 PM   #2
Awsome!! You can't beat those wheels.
Kamikaze is offline   Reply With Quote
Old 01-11-2009, 03:16 PM   #3
Damn dude...those look awsome.
nj05nismo is offline   Reply With Quote
Old 01-11-2009, 03:27 PM   #4
They turned out great
joesbruiser is offline   Reply With Quote
Old 01-11-2009, 03:51 PM   #5
I like the way they fade in to the center with the darker rings out towards the ends. Maybe hit up the lock rings with a coat of black and it would really set it off.
CRAZYACE63 is offline   Reply With Quote
Old 01-11-2009, 06:15 PM   #6
First up, those rims came out sweet
Maybe a silly question.........but does boiling delrin for an hour do anything to the integrity of the material ?
Shorty40 is offline   Reply With Quote
Old 01-11-2009, 06:28 PM   #7
No integrity issues the delrin is pretty resilient. It just take longer soak times since the delrin is so dense. If you let them soak for a short time they are more semi-transparent. You really don't need to actually boil them just keep the hot.
Old 01-11-2009, 06:39 PM   #8
Those turned out nice Steve.
Rockcrawler is offline   Reply With Quote
Old 01-11-2009, 06:41 PM   #9
Any idea how deep the dye goes? When they scratch, will you see white again?
Harvo is offline   Reply With Quote
Old 01-11-2009, 07:13 PM   #10
It penetrates fairly deep. It will take some pretty good scratches to get to the white. I'll gets some pics of the depth of the dye later.
Old 01-11-2009, 07:20 PM   #11
Nice work , those are b..a..utiful!!
Bundy is offline   Reply With Quote
Old 01-12-2009, 01:30 PM   #12
thats a great color. With the amount of dye choices out, you could pretty much make any shade you want.
860Crawler is offline   Reply With Quote
Old 01-12-2009, 02:26 PM   #13
i want to see the those pics you posted but it not show up on my computer that pic link seem broke?
Lil Toy is offline   Reply With Quote
Old 01-12-2009, 03:36 PM   #14
I don't know what to tell you I've got 3 different pc's here they all see them. Maybe some of the computer gurus on here can help
Old 01-12-2009, 03:38 PM   #15
Yeah pretty much an infinite potential
Old 01-12-2009, 04:20 PM   #16
what kind a price are they?
losijay is offline   Reply With Quote
Old 01-12-2009, 04:24 PM   #17
PM or E-mail Mayhem he'll hook ya up
Old 01-12-2009, 04:27 PM   #18
Just thought I would add a couple of pics of the completed Wheel/tire combo.
Front
Backside
Old 01-29-2009, 03:03 AM   #19
Thank to ya TEDROCKZ that now I can see the rim, it look sick!
