03-26-2009, 05:17 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
| offset wheels?
what is the point and what is it 335 460 585 rockforce 335 |
03-26-2009, 08:07 PM | #2 |
no one knows?
03-26-2009, 09:43 PM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
when a wheel is offset it means that the mounting surface isnt exactly center, by chaning your off set you will make your track narrower or wider depending if the off set is positve or negitive
03-26-2009, 09:55 PM | #4 |
what is better?
03-26-2009, 11:10 PM | #5 |
depends on driving style / terrain etc wide open go for a wide track, alot of tight narrow spaces you will want to be narrower , and if you want to compete it has to fit within certain messurements.
03-27-2009, 05:25 AM | #6 |
Rock Crawler Join Date: Sep 2007 Location: University City
your axle width also plays an important part. On a tlt or axial axle your gonna want a wider offset, and on a berg or clod axle your gonna want a narrower offset. Usually around 9.5-10.5 is pretty good for comp trucks. On my last rig i ran a 9.5 rear and a 10 front and it was perfect. With the berg axles even with the narrowest offset wheels my rear is still at 10" even.
03-27-2009, 04:06 PM | #7 |
Rock Stacker Join Date: Mar 2009 Location: Angeles City, Philippines
what would be the advantage of having a wider front track width?
03-27-2009, 05:42 PM | #8 |
its more of an advantage to having a narrow rear track width. The wider front track width makes the truck more stable, but having the narrow rear means you can cut a gate closer in the front and not have as much concern about hitting the gate with the rear wheels.
03-27-2009, 06:10 PM | #9 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
03-28-2009, 12:52 AM | #10 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
585 is about 1/4 per side more narrow than stock ax 10 wheels, Revolvers are very close to stock 460 are 1/8 per side more narrow than 585, and 335 is currently the narrowest |
03-30-2009, 04:42 PM | #11 | |
