04-25-2009, 10:52 AM | #1 |
Rock Stacker Join Date: Apr 2009 Location: Ontario Canada
| So whats inside your tires?
As I am just getting into crawling I have many questions, what do you run inside your tires, right now I just have the standard foam that came with my Axial Scorpion kit, but I have heard some people remove the foam and use air pressure, some use BB's some leave the foam and vent the wheels? What do you think works best? |
04-25-2009, 10:55 AM | #2 |
Newbie Join Date: Mar 2009 Location: Hartford
Right now I am using proline memory foams and a couple wraps of stick on weight inside the tire. |
04-25-2009, 11:00 AM | #3 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
i run proline Chisels and i am running vented rims, stock foams and 5.5oz of weight in the front and 2oz in the rear, thats per tire. you dont want to use pressured air, it will make your tires bouncy and uncontrolable
04-25-2009, 11:03 AM | #4 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Air and foam. |
04-25-2009, 11:14 AM | #5 |
Quarry Creeper Join Date: Jan 2008 Location: Calabash, NC
Old school. Star cut foam and vented rims. |
04-25-2009, 11:28 AM | #6 |
RCC Addict Join Date: Jan 2009 Location: ?????
im runnin the rovers with the nwtt hybrid reachs' with about 8oz per front tire and 4.5oz per rear and they do great.....my rims are also vented with one 1/8" hole per rim
04-25-2009, 12:06 PM | #7 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
I run Panther F400 standard non-cut foams... with vented tires and wheels. They are the best foams i have ever used...and they are cheap, simple, and consistant. |
04-25-2009, 12:12 PM | #8 |
Quarry Creeper Join Date: Apr 2009 Location: Ukiah
I run the stock Axial RTR rims with HB soft Rovers, using stock foam, 1/8" drilled hole in all four rims and 9oz stick weight in each front rim and 4oz in each rear wheel. Will be replacing the stock foam with proline stage 2 shortly. Eric |
04-25-2009, 12:40 PM | #9 |
awesome thank you all for your input, I think I will try star cutting the foams, I am guessing just a sharp razor blade is best way? and I will drill the 1/8th" hole As for the weights, what seems to be best strapping them to your axles or to stick em inside the rims? |
04-25-2009, 02:21 PM | #11 |
Quarry Creeper Join Date: Jul 2008 Location: Asheboro N.C
I am running rovers on vented Mayhem wheels, the foams are stock rovers with a custom foam in the back, will be replaced by proline 2 stage someday.
04-25-2009, 02:28 PM | #12 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
I'm running NWTT allweather squats in front and full losi claw foams in rear, with Losi Claws mounted on aluminum MSD rims with couple wraps of lead rope in front nothing in rear.
04-25-2009, 04:31 PM | #13 |
Rock Stacker Join Date: Apr 2009 Location: New Jersey
for you guys using vented wheels, how many holes are you drilling in them ? im new to crawling and am trying to find what works for me.
04-25-2009, 07:22 PM | #14 |
im just runnin one 1/8" hole per rim, i would say that that would be a good start and then just go from there as to what you think works best.....
04-25-2009, 07:23 PM | #15 |
Newbie Join Date: Jan 2009 Location: Kelowna
taped on nickels and vented rims
04-25-2009, 07:53 PM | #16 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
I am running Proline Straight 8 rims http://www.tcscrawlers.com/Proline-R...3-p-16804.html Losi Rock Claws tires http://www.tcscrawlers.com/Team-Losi...B-p-16414.html NWTT All Weather Hybrid Reach foam http://www.tcscrawlers.com/All-Weath...h-p-16840.html 7.5 oz of weight in the front wheels and 3 oz of weight in the rear wheels 2 vents holes in each wheel, approximately 180 degrees from each other on the other side of the rim. I drilled my vent hole through the weight and the rims. You have to test different setups to see what works best for you in your location and with your driving style. Remember it takes a little time for your tires and foam to break in and work their best together. Hope this helps you with your foam selections |
04-25-2009, 08:38 PM | #17 |
Newbie Join Date: Mar 2009 Location: Cle Elum
im runnin the best... star cut foam, and my own urine. Cuz its sterile and i like the TASTE... haha
04-25-2009, 10:01 PM | #18 |
Rock Stacker Join Date: Feb 2008 Location: Uhh.....
04-30-2009, 11:37 PM | #19 |
Pebble Pounder Join Date: Apr 2009 Location: Ogden
Proline memory foams with 12oz of lead in the front and 3oz in the rear |
04-30-2009, 11:47 PM | #20 |
so I most defiantly need weight in the front I have found this out while I have destroyed 3 plastic servo's... I need a new hi torque metal geared one hehe
