05-02-2009, 10:18 AM | #1 |
Rock Crawler Join Date: Apr 2008 Location: Greentown
| how do you get BB's in your tires and run foams??
Hey guys, instead of wasting $50 on wheel weights, i have a couple box's of metal BB's.... I weighed them, but im not to sure on how to get them to stay in the wheel, are they supposed to roll around in there and be sandwitched between the wheel/foams? Or do you stick them to the wheel somehow??? Thanks-and sorry for the noob question, i searched but couldent find anything on what to do with the BB's... Thanks! |
05-02-2009, 10:43 AM | #2 | |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I got enough stick on wheel weights from CKRC to do 2 rigs for $10. I've never run BB's, but if I did I would probably tape them to the inside of the wheel somehow between the wheel and foam. | |
05-02-2009, 11:34 AM | #3 |
Newbie Join Date: Mar 2009 Location: holden
I ran bb's in my tires for a little while and i just trimmed the foam enough to allow the bb's to roll around inside, but they still would get clogged up and throw the wheel out of balance. So i went to Bass Pro and found this. Its a 5lbs bag of lead for about 22 bucks. Its used to melt down and make homemade sinkers out of but it is the perfect width to fit inside the rim and it cuts super easy with a good pair of scissors. I just taped it to the rim. |
05-02-2009, 11:52 AM | #4 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
Channel cut the center of the front foam. For berg go 16oz of total front weight per tire and shafty go 12oz per tire and no weight in the rear.
05-02-2009, 01:05 PM | #5 |
make a pouch of tape for them and wrap ur wheel
05-02-2009, 01:51 PM | #6 |
The purpose of running bbs or sinkers or lead shot is so that they are constantly rolling at the bottom of the tire so the cog stays down really low and the bbs conform around the rock with the tire. There is no piont in just taping them to the wheel. You might as well just use lead sticker weights to do that.
05-02-2009, 02:39 PM | #7 |
Newbie Join Date: Oct 2008 Location: London
| Agreed
The BB's should roll to the bottom of the tire which IS the whole point. I used them in narrowed clod wheels/tires (no foams) and they did work but they were noisy and annoying. I like the lead weights now !
05-02-2009, 07:25 PM | #8 |
| ok thanks guys, ill try that out. I was thinking more like 6 oz. a tire in the fronts, and 4 oz. per in the rear?
05-03-2009, 12:33 AM | #9 |
Newbie Join Date: Oct 2008 Location: in a house
i used pennies in my wheels. taped um up. worked great. |
05-03-2009, 02:17 AM | #10 |
Newbie Join Date: Jul 2008 Location: Salida
05-04-2009, 01:57 PM | #11 |
Rock Stacker Join Date: Jul 2008 Location: The County Hell
05-29-2009, 06:50 PM | #12 |
Newbie Join Date: May 2009 Location: Marysville
| The BB's
A buddy of mine cut a deep V shape into the foam of the front tires. Placed the BB's in the tire and and he doesn't get any clogging. His truck is super heavy. I am not sure how much weight he put in but I think it was a little extreme. I think he said 5 lbs per front wheel. Maybe 2.5 lbs per front wheel. I know it was a ridiculous amount. I am thinking of trying the idea myself. I get a lot of back flips.
05-29-2009, 07:21 PM | #13 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
| Go to the auto parts store and get 30 sticks wheel weights. Less than 20.00.
05-29-2009, 07:42 PM | #14 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
| BB's NO foams I ran 9oz of (steele) bb's in each front wheel. and 4oz of air soft bb's in each rear. As mentioned earlier the purpose of using bb's is to keep your cg at it's lowest point. I ran the airsoft in the rears for two reasons. 1. to give just a little weight. 2. to help keep a little shape to them. Getting them into the wheel is very easy also. Set one side of the tire bead into the wheel, and make sure all the screws are tight. Add your bb's. Set the other bead and tighten all the screws. Put em on your rig and have fun. |
05-30-2009, 08:45 AM | #15 |
I joined the Band! Join Date: May 2009 Location: anaheim
I used epoxy to glue lead buckshot to the rims. Im not into the idea of them rolling around in the tire.
05-30-2009, 09:50 AM | #16 |
Quarry Creeper Join Date: Nov 2006 Location: RENO, NEVADA
bb's are in the olden days braah..
05-30-2009, 11:55 AM | #17 |
Check out DirkDiglers thread "poor man's wheel weights".
05-30-2009, 01:14 PM | #18 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
I use to run airsoft bb's in my tires, about 3/4 tire full in front and about 1/2 in rear. The airsoft are light enough to use alot to fill the tire and helps keep tire from rolling over on side hills, but adds enough weight to keep the tire planted. They worked well but the noise gets old after a while.
05-30-2009, 01:45 PM | #19 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
I to cut deep V's in my foams and weighted both front and rear. Not telling how much....mostly cause I forgot. Have M3 compound tires and works really well on my scaler.
05-30-2009, 02:33 PM | #20 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Lead rope is ez to find at most sporting goods-fishing stores and is cheap.Works great and is ez to work with. |
