07-07-2009, 09:29 PM | #1 |
Rock Stacker Join Date: May 2009 Location: Chester VA
| Wheel weight help
Hey all - I have a modded cliff climber and im running Losi Rock Claws with stock foams that came with it and RPM Revolver wheels that are non beadlocks. I want to add some weight to them, so I have a few questions. Do I need to trim the stock foams at all? I was thinking of 5oz in each from and 2 in each rear, is this enough or okay? I have a modded cliff climber and it needs weight to help keep it planted. Thanks for any help!
07-07-2009, 10:46 PM | #2 |
Rock Crawler Join Date: Jun 2007 Location: Arlington
The weight sounds good, and I have run stock losi foams with plumbing solder for weight without trimming them. I eventually ended up with channeled memory foams. The solder is wrapped tightly around the wheel, and the highest part sits in the channel. |
07-08-2009, 07:07 AM | #3 |
Cool, so should I eventually change the foams? I want to get beadlocks at some point but for now this set up is nice. So when I switch to beadlocks, maybe put memory foams in then?
07-08-2009, 07:11 AM | #4 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Befor I got my Vanquish rims I ran 7oz in each front and 3oz in each rear with the a channel cut in the middel and rounded the outside.
07-28-2009, 09:12 PM | #5 |
Newbie Join Date: Nov 2008 Location: Somewhere in, Illinois
anyone got any info on sticky weights. im thinkin about puttin on top of the axles cuz my wheels dont support putting weight in and theyre a pain to take apart. -Thanks |
07-29-2009, 01:46 AM | #6 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
| tires
What kind of wheel and tires r u running , and is it on a Shafty or MOA
07-29-2009, 09:33 AM | #7 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
07-29-2009, 11:47 AM | #8 |
Quarry Creeper Join Date: Mar 2008 Location: Zachary
07-29-2009, 01:40 PM | #9 |
its an scx10, stock wheels with the proline flat irons. if by shafty you mean shaft driven yeah it would be. its just too light and i dont wanna dish out money on exspensive aluminum rims. when it articulates, one corner sometimes comes up but with only slight pressure(like me pushing it truck down a bit) the wheel can make contact with the ground and the suspension can still travel to accomidate. also it will help on the steep inclines. right? -thanks |
