09-09-2009, 07:12 AM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: Clarksville
| What middle ground tires for loose and slick rock and dirt?
What's a good middle tire between rock and dirt? We have a lot of slick and smaller jagged rock, rather than course bolders, here in TN. Im not competing and do run up steep dirt trails also, in search of rock. Im currently running stock Axial Hammers. I see some ppl run Mashers or Rock Grabbers and wondered how those would do. Hammers are terrible on slick rock and worthless in the dirt.
09-09-2009, 09:12 AM | #2 | |
I have FlatIrons on my 2.2 scaler. I have cut some of the lugs out and made them a lot better in the dirt. You can see the cuts in this pic. | |
09-09-2009, 10:19 AM | #3 |
how do the mashers do on rock though? it looks like flat irons may be the best tire to go with for both rock and dirt. i know not one tire is great at both so just looking for something decent at both.
09-09-2009, 12:10 PM | #4 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
If you go with the mashers, make sure you get the Masher 2000 and not the original Masher. The 2000 has a better compound for rocks.
09-09-2009, 01:52 PM | #5 |
what about 40 sized tires? anyone running that size on crawlers?
09-09-2009, 05:11 PM | #6 |
09-09-2009, 05:18 PM | #7 |
Newbie Join Date: Sep 2008 Location: Upper Deerfield
I run mashers and think they work great. Turn the backwards on rocks and they still do well on dirt.
09-09-2009, 07:11 PM | #8 |
Thanks. Ill stay w/ the 2.2 and try the mashers then.
09-09-2009, 08:16 PM | #9 |
Back in the day Mashers were all we had. They were good then and they're good now. M2 compound seems to work best.
09-10-2009, 08:04 AM | #10 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
With the open pattern the new Panther Leopards might work really well for you. |
09-10-2009, 02:59 PM | #11 |
Rock Crawler Join Date: Sep 2007 Location: University City
my all around tire list would include badlands and rock grabbers. Those are also my top two choices for crawler tires.
09-10-2009, 06:20 PM | #12 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I have 1.9 flat irons which I use mainly on loose gravely dirt and plain dirt. The dirt usually has a tiny bit of moisture in it. The FI tends to load up pretty quick even if the dirt has the slightest bit of moisture. When they load up they get slick and don't seem to clean very well.
09-10-2009, 08:59 PM | #13 |
Rock Stacker Join Date: Oct 2005 Location: Greeneville,TN aka BFE
i live in TN and have had a set of hammers and have found that i like the losi claws the best with the hammer's memory foam and well vented rims. i too dont comp and just trail ride and hit the big rocks every once in awhile, hope this helps u out and good luck.
09-12-2009, 02:07 PM | #14 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
I've had the M3 compound M2K's on my Wheely King nearly 2 years with the PL Memory foams on Axial rims and have had them work great in everything I've run it through. I've also swapped my Losi Comp Crawler over to the M2K's as well (stock foams in the back Memories in the front) on the stock rims and they seem to work great so far and look pretty aggressive too |
09-12-2009, 05:41 PM | #15 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
So no one thinks rovers are best all round tire out there??????????????????? And they comp pretty good too. |
