11-12-2009, 10:30 PM | #1 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
| Mounting SLW's to upgraded axle shafts!
Got my hands on a set of Vanquish SLW's only to find I couldn't mount them because of my beefy (letshandleit) 5mm axle stubs Determined to get these great wheels on my bully for their weight savings and the taller tire from the .7 size I came up with this quick and easy fix to mount them on the 5mm stubs First a bought (4) 5m aluminum couplers Then I chucked them up in the lathe and rounded off the hex to fit in the insert (It was that easy) Since they don't have nylon threadlock is in order! |
11-12-2009, 10:38 PM | #2 |
Cool mod but my super 300's fit through and they are 5mm. So thats weird. :?
11-12-2009, 10:50 PM | #3 | |
Hey Brad or Chris do you think this would be better in tires and wheels? If you could can you move it for me Thanx Last edited by Mr Glassman; 11-13-2009 at 07:57 AM. | |
11-12-2009, 11:06 PM | #4 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
with the additional thread you could use a set screw to act as a thread locker. It'd work far better than just loctite alone, or even the usual nyloc nuts would..
11-12-2009, 11:48 PM | #5 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Hmm I just chucked my HB lightning flanged 5mm nuts in the drill put it on the highest speed and just filed them down till they fit. That way you get the most surface area against the rim and the stick out enough to be able to use a standard T or Y wrench. I am running V2 axles which are 5mm all round. Kieren |
11-12-2009, 11:57 PM | #6 | ||
11-13-2009, 12:03 AM | #7 |
11-13-2009, 02:55 AM | #8 |
No I am running Berg V2 axles Kieren |
11-14-2009, 12:17 PM | #9 |
Quarry Creeper Join Date: Feb 2009 Location: Warwick
I used the Traxxas 5 mm flanged nut with the flange turned down to fit inside the VP hub. I can still use a standard 8 mm nut-driver to tighten the nut down no problem ...the nut is deep inside the hub BTW |
