11-09-2004, 03:36 AM | #21 | |
Rock Crawler Join Date: Nov 2004 Location: roanoke
| Re: triangles/squares instead of hexes Quote:
(tryin to help out, only been here like a week) | |
11-22-2004, 10:50 PM | #22 |
Rock Stacker Join Date: Nov 2004 Location: dallas tx
Guys im in 8th grade math and my teacher said to me that the triangle is the strongest geometrical shape and i also asked her the question about what you guys were talking about and she of chorse didnt know what i was talking about so i drew her a pic and she said shed go with a triangle because it has the least resembelance of a circle ...but over all what we want is a shape that is strong enough to hold the pin in and a shape strong enough to not strip in the rim right???? and the triangle is going to get weaker on the tips of the axes right??so i thought id go with the square just because its got more beef to it and if you put the pin sideways you would have more strength right??? but oh well thats just my 2 cents i like to here what you guys' minds are thinking though it interesting thanks jason b |
05-12-2005, 03:53 PM | #23 |
Pebble Pounder Join Date: May 2005 Location: Hacienda Heights
What are some solutions to fixing this problem(stripped wheel hubs) the only thing i can think of is liquid nails, i also herd of wrapping the outside of the metal hex with tin foil. I am all out of ideas and dont want to buy new wheels or tires. I burnt out all 4 wheel hubs in less than 3 days
05-12-2005, 04:31 PM | #24 |
Newbie Join Date: May 2005 Location: Augusta
5th scale and 1/4th scale use squares. The ue hex is a wonderful idea. Too bad Robin didnt measure the wheel correctly and get the proper size. Its a wee bit smaller than the wheel, and to add insult to injury they decided to round the edges to remove any possibility of using a plastic wheel with any form of power. Its almost as if they want you to run their wheels. Im sure that cant be the case though. |
05-12-2005, 04:44 PM | #25 | |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
05-12-2005, 04:44 PM | #26 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
I think a square with a cross pin going from point to point would be WAY better than a hex!
05-12-2005, 04:54 PM | #27 |
Pebble Pounder Join Date: Oct 2004 Location: Colorado
Have you ever seen a tapered axle like the old CJ2A Jeeps had for their wheel hubs. Those suckers will sometimes take heat, pounding, and lots of cussing to separate. If you used something like that on a crawler wheel, you would just eliminate the keyway and let the frictional forces hold the wheel to the axle. But then we would all have to switch over to metal wheels. |
05-12-2005, 05:10 PM | #28 | |
Quarry Creeper Join Date: Jan 2005 Location: Denver, CO
05-12-2005, 05:28 PM | #29 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
i think the way to not strip out your hexxes and whatever is to make shure they are properly instaled and are titened corectly. ive never striped any thing useing this method. |
05-12-2005, 06:20 PM | #30 |
Pebble Pounder Join Date: Mar 2005 Location: Utah
Just my two cents the subject. I am a mechanical designer and work in an engineering office. First, the "Triangle is the strongest geometric shape" argument. When this is said it's referring to structual members, this is not what we are doing with transmitting power to our wheels in R/C trucks. This is why you see trusses on bridges with thier members arranged in ways that form tirangular shapes, this is an entirely different situation than what we are talking about. However, I do think a triangle would be stronger, but for a different reason. If you look at the angles of the force being applied at the edges of whatever shape you are using the angle that is the greatest from the edge of the shape will give you the shape that will least likely strip out. Think of a circle running around the hex at it's points, that's the force that is trying to strip the hex. For simplicity sake, imagine one of the hex corners sitting straight up, then take a line straight off that corner parallel with the ground. Now look at the angle this line makes to the side of the hex. Now imagine a triangle or even a square in the same situation. That angle is much greater, which means it will take more force to overcome the shape and cause it to strip. That said however, I don't think the hex drive is a bad design, it's just often executed poorly. If there is any slop in the hex to wheel fit then you're almost guaranteed to strip it. The pin only design is very poor, circles strip very easy. You have very, very little contact area with a pin. I beleive the best design for power transfer would be a blade, assuming it is thick enough and long enough. Even with slop in the slot it will not strip. David |
05-12-2005, 07:35 PM | #31 |
Quarry Creeper Join Date: Mar 2004 Location: 18" from computer screen
what about a star shaped drive adapter? simple to manufacture, and if done correctly it should be stronger than a hex. Also, have we considered that it is not the shape, but the material of the hex that is the downfall?
05-12-2005, 07:40 PM | #32 |
i think that a triangle or square would were quiker and have alot of play in it. also, why would the axle shafts on a 1:1 be round (with splines) and not triangle if round was weeker. :?
05-13-2005, 07:08 AM | #33 |
Here is a link to a drawing of a 5th scale front end. Notice the Hex's. Square hex |
05-13-2005, 10:44 AM | #34 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I know in some industrial applications this style of shape holds up well. I know it would obviously take some work to get a wheel made to acccept it but I think that this type of hub would be very strong for power transfer and durability. http://www.freepichosting.com/Thumbs...22/154/156.jpg |
05-15-2005, 12:24 PM | #35 | ||||
David | ||||
05-15-2005, 02:05 PM | #36 |
Rock Stacker Join Date: Aug 2004 Location: wasatch front
the ideal idea would be to create a hub just like a real car and have like three nuts holding the wheel to the axle. it would be strong and look realistic.
