Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: 1.9 wheel weights ???
Old 12-31-2009, 08:42 PM   #1
Default 1.9 wheel weights ???
Question ??? how much wheel weight do you add to your scalers front & rears, I have 3oz's on each wheel right now, does anybody run more than that ???
luv2ridemx is offline   Reply With Quote
Old 12-31-2009, 08:48 PM   #2
On the lookout for Rocks
constantmotion's Avatar
I usually just run a full wrap in the front (3 3/4oz on Axial 1.9s) and none in the rear.
constantmotion is offline   Reply With Quote
Old 12-31-2009, 09:28 PM   #3
Default thanks
I know the more weight you have on the front & rear wheels the more stable your rig will be, I had like 8oz's in each wheel on the front & 3oz's each in the rear, it just seemed like to much to have in the front though, its smashed the tires while turning up front.
Old 01-01-2010, 09:23 AM   #4
I run 4 of these CKRC Losi MRC beadlocks http://www.ckrccrawlers.com/shop/ind...oducts_id=1207
with G8 Flat-Irons and my battery & ESC up front & my Toyota SCX10 climbs like a goat
each wheel with tire on it, is just under half a pound
prusik333 is offline   Reply With Quote
Old 01-01-2010, 01:24 PM   #5
dkf
4oz in the front 2 oz in the rears.
dkf is offline   Reply With Quote
Old 01-01-2010, 10:52 PM   #6
Im right around 9.5 oz per tire, all tires. I needed mine extra heavy
Losi MRC
mikegigabyte is offline   Reply With Quote
