04-26-2010, 08:29 AM | #1 |
Quarry Creeper Join Date: Oct 2008 Location: florida
| Need help on wheel choice
I want to get the Vanquish SLW wheels for my Axial and I'm driving myself crazy as to which one to order. I will be using the Zero ackerman knuckles and a home made bta steering. I was thinking of .7's in the front w/725 or 850 hubs and 1" rear with 600 or 475 hubs. I want the front a little wider than the rear. Does this sound like a decent combo or whats your recommendation?
04-26-2010, 09:12 AM | #2 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
If you run comps, I'd consider making the front wider than the rear. Makes it easier to clear gates.
04-26-2010, 09:17 AM | #3 |
Yeah I do want the front track wider than the rear, do you think a wider wheel on the rear would be any benefit?
04-26-2010, 10:06 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
According to your first post, you have the wider wheels on the back and the .7s on the front. That seems backwards to your goal, is that a typo?
04-26-2010, 10:53 AM | #5 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
honestly I'd go with the DH's. the slw's you have to stuff with weight. If you do stay with the slw's go with .7 in the back, and 1 or wider in the front. It depends on the tire also. the sedonas I run seem to like the 1" wheels DH procomp |
04-26-2010, 12:16 PM | #6 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
only time being narrow in the rear will hurt you is in 2 instances: 1. off camber, your truck will side hill better if the width is equal. It isnt going to be real noticeable, but it will be less stable if the rear is narrower. 2. more noticeable will be climbing a v notch or grove, when you are trying to straddle a v while climbing the rear will want to fall in easier if it is narrower. there were several occasions that i was playing around with practicing that i had to fight to get through narrower in the rear, changed wheels and walked right up/through the some areas. with that said, i stuck with it 1/2 overall narrower in the rear than the front. i wouldn't go any narrower than 1/2" overall 1/4" per side, but thats my opinion. being narrower in the rear allows you to turn better, dig better, and clear gates easier. |
04-26-2010, 12:49 PM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
I would go with dh's up front and a .7 v4 slw out back. As for adapters I have no clue as I run bergs but I would shoot for 9.75-10 in the back and 10-10.5 in the front! |
04-26-2010, 01:14 PM | #8 | |
I thought having a skinnier tire up front will allow a tighter turn? Last edited by motorman; 04-26-2010 at 01:41 PM. | |
04-26-2010, 01:24 PM | #9 |
Quarry Creeper Join Date: Aug 2009 Location: Gamecock Country
1" SLW V2s front and rear. 725 hubs in the front and 600 hubs in the rear. You can go to O'rileys auto parts and get Mr.Gasket wheel weights (4-2oz. strips per pack) that will fit right in the channel of the wheel. 3 packs will give you 8oz. per wheel front and 4oz. per wheel rear. That's what I'm running with good results. Just my opinion.
04-26-2010, 02:05 PM | #10 | |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
( insert rockshow voice ) Now im not saying that this is the best setup, " im just saying" that it "is possible" that "this may or may not be" a " potential " setup for " someone " to run... | |
04-26-2010, 02:11 PM | #11 |
so with a 1" SLW wheels with a .725 hubs will that have a 9.17 width? (outside to outside) and would the .850 hubs have a 9.342 width? |
04-26-2010, 06:12 PM | #12 | |
Rock Crawler Join Date: Mar 2006 Location: North Carolina
I can not confirm or deny that I would ever say something like that! P.S. When did you start letting Steve post using your name? Last edited by Rockshow; 04-27-2010 at 07:50 AM. | |
04-26-2010, 07:23 PM | #13 | |
When you are climbing uneven ledges or going down uneven steep grades... the narrow rear will try to line up behind the front sometimes throwing the rear quickly to either side. If there is a gate there, it's hard to miss. At least thats my experience with really narrow rear width. | |
04-27-2010, 06:38 AM | #14 | |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
04-27-2010, 08:09 AM | #15 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
