05-19-2010, 11:20 AM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
| Nova foam sizing....
Ok, I'm talked into trying a set in my white rovers on 1" wide Mayhem wheels. What width do I need? 2.250/2.125/2.0 Thanks!
05-19-2010, 12:02 PM | #2 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
As long as you are comfortable trimming your inner foams yourself, I always recommend 2.25 wide foams. That way you can tune them for your specific crawler. My original design was 2.25 wide inner foams. There are a few questions that must be considered before trimming your inner foams. 1. How much does the crawler weigh? Or what is the target final weight of the build? 2. How wide are the rims being used? 3. Are those wheels / rims grooved or channeled in the center? 4. What tire is being used and what compound is it? 5. Is that tire siped and grooved? To further explain, a few of those questions; 6 pounds and liter need a soft foam (narrower inner foam). 6 pounds and heavier need a much firmer foam (wider inner foam). .7" and 1" wide wheels in general like a 2 inch wide foam. Anything bigger than 1" will want a wider foam. Also, a wheel that has a channel in it like a RC4WD, Axial, Pro-Line, etc will need a wider foam or have the channel filled. Nova Foams need a flat surface to work off of. Both Vanquish Products and Mayhem Engineering brand wheels have a flat surface and those are the two brand wheels I use and have done most of my testing on. Tire compound; a firm tire compound will need a softer foam and narrower inner foam. A soft tire compound will need a wide inner foam. Siping and grooving tires really softens them up. If you are going to run siped and grooved tires, I recommend you do the tires first and then trim the foams. For example, I had a set of tuned foams in some white dot rovers. I then decided to sipe and groove the tires real crazy. The tire softened up so much I had to install a new set of inner foams 1/8 wider. That is one of the reasons I designed the tuning discs. I think that covers most of it. If you have any other questions, let me know. You can always PM me here on RCC or email me direct at: novasark@crawlerinnovations.com Thank you for your interest in my products. Eddie |
05-20-2010, 08:18 PM | #3 |
Quarry Creeper Join Date: Oct 2008 Location: Valley Village
Hy pappy and nova! Good question pappy, & great answer/411 Nova. I got mine in the mail today thanks for posting. Time to screw They look very nice, super fast shippin too. Thanks for the stickers Im installing on mayhem comp phattyz |
05-20-2010, 10:40 PM | #4 |
All done, Great foams! thanks |
05-21-2010, 08:19 AM | #5 |
cornsnake those are cool pictures. Thank you for posting them and the compliment on the product.
05-22-2010, 09:00 PM | #6 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I got the 2.25" wide 2 stage foams. Mounted them on LCC wheels, front weighted with white Rovers, rears no weight with blue Rovers. The LCC wheel is 1" wide with a channel/groove in the center of the wheel. They went together real easy. Have yet to run them but they feel alot better compared to stock Rover foams. Thanks Nova for the extremely fast shipping... |
05-22-2010, 09:26 PM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
i left mine the way they came on dh procomp wheels they work great they got here faster than thought there going thank for such go costomer service NOVA'S 2'2 ROCK |
05-25-2010, 12:17 AM | #8 |
I did the 2.25's on mine and I am very happy with the foams and Nova's customer service!
05-25-2010, 12:34 AM | #9 |
I got 3 of the four installed so far......Put them on UCW's......I cut out for the ring width on the inner foam, and put all of the remaining foam in, and said there ain't no way that is gonna fit in there!.....Well it does, and they look great so far!!! I finally got Rovers as tall as they should be!!!! |
05-25-2010, 09:27 PM | #10 |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
I have Rover's but there only sitting at around 5 inches tall. If i were to get Nova foams they would sit at around 5.5 inches tall?...correct? |
05-25-2010, 10:26 PM | #11 | |
I got to run a pack through mine on my rocks today.....These foams rock!!! Eddie referred to his team driver that runs a similar setup to me, and he was very very helpful. Great product and customer service!!! A+ x 100!!! | |
05-26-2010, 10:02 AM | #12 | |
Awesome!!! Reading comments like yours brings me joy. Thank you for that feedback. That made my day today. | |
05-27-2010, 01:34 PM | #13 |
| Kickass Pappy, glad you got it worked out, I knew you would be pleased with the results! |
05-27-2010, 10:12 PM | #14 |
Rock Stacker Join Date: Sep 2008 Location: nor cal
Do the two layers of foam need to be glued together? to help them from shifting on side hills.
05-27-2010, 10:21 PM | #15 |
05-30-2010, 05:11 PM | #16 |
WNYRCRC Join Date: Nov 2008 Location: Western New York
Hey Pappy. I run 2.25 in the front on Vanquish Dhpro comps. I run the 2.0 in the rear on. 7 slw's. I have been running sedonas. The foams are awesome. I did cut the channel in the fronts when I ran the ucw's for the rings. Good luck man.
07-08-2010, 01:26 PM | #17 |
Pebble Pounder Join Date: Jun 2010 Location: everett
| question
I just ordered these wheels http://rc4wdstore.com/2/product_info...e32922108657c0 and want to order your foams for them today, the wheels measure 1.49" wide. i have an axial with an bender chassis. rover white dot tires, unfortunatly i have no idea what the car weight is. what foams would you recommend? also what is the best way to fill in that channel with out adding a ton more weight? Thank you |
07-08-2010, 01:42 PM | #18 | |
09-02-2010, 06:39 PM | #19 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
First, I apologize for the hijack I have come to realize the stock foams in my Chisels are way too soft! I have a couple quick questions. My rig is just a tad over 6lbs so I'm not quite sure what to get. My wheels are PL 8 shooters (1.1") with 14oz in each front and 8 1/4oz in each rear. No siping just yet (they are very new). Any help is greatly appreciated! P.S. I may be answering my own questions by going with 5.5 DD with 2.25 inners? Thanks! |
09-02-2010, 06:53 PM | #20 | |
