09-11-2010, 05:49 PM | #1 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| beadlock/bead issue?
not major, but has anyone dealt with this? and found a decent non-permanent solution? it looks as though the wheel has spun inside the tire, its nothing to major as this is the first time i've even seen it happen. I was almost afraid to keep crawlin, as the sidewall was bound up tight on the rim, I was feelin for those poor soft sidewalls |
09-11-2010, 06:18 PM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: Edmonds, WA
looks like you were drag racing i've never seen that before though.
09-11-2010, 06:31 PM | #3 |
i've seen the sidewalls ripple before, but never the wheel turn inside the tire |
09-11-2010, 06:48 PM | #4 |
I've seen some tires do that if the bead lock bolts aren't tight enough on one side. They will spin on one side, not the other. It's hard with the small hardware and plastic on the stock wheels but you might try to snug them down a bit more, may help.
09-11-2010, 06:55 PM | #5 |
Rock Crawler Join Date: Jan 2009 Location: San Gabriel, Crawlerfornia.
Ive done this before but it was cuz i didint have vent holes.
09-11-2010, 07:47 PM | #7 | |
maybe I should look into foams for this thing. | |
09-11-2010, 08:49 PM | #8 | |
09-11-2010, 08:51 PM | #9 | |
