11-28-2010, 11:04 PM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Denver
| How do you guys make your tires so squishy
I just picked up a new Honcho, and the tires seems so stiff. There soft, dont get me wrong but I see all these pics and vids of your guys rigs and the tires seem so much more pliable. They really grip the rocks that way. I know when I wheel for real in my Jeep I air down, and it seems like you folks are almost doing this...but how? Thanks |
11-28-2010, 11:34 PM | #2 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
The easiest way is to drill a small hole in the wheel to allow the air to move in and out. Though I am not sure if you want to so that with this being a scaler and the potential that you may do through water. I guess the other way is to take off one of your bead lock rings, sqeaze some of the air out and then re mount the ring
11-28-2010, 11:57 PM | #3 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
If you squeeze air out of the tire it will be "deflatted" and have flat spots. Just drill a hole or two in the inside of the wheel, if you don't like it put some silicone or shoe goo over the holes. But every project I have done there has been a hole to allow the tire to compress and give the rig a better ride(getting rid of some of the bounce). If you still find it too stiff you can start tuning your foams. But first step one. |
11-28-2010, 11:58 PM | #4 | |
Thanks | |
11-29-2010, 12:00 AM | #5 | |
DO you have a link on how to "tune" the foam? Thanks so much folks. | |
11-29-2010, 12:18 AM | #6 |
Just try a search for "foam tuning" there is heaps of information for tuning different types of tires all of which can be applied to your particular tires.
11-29-2010, 12:46 AM | #7 |
RCC Addict Join Date: Feb 2007 Location: Simpsonville, SC
depending on the beadlocks, i have drilled breather holes into 2 of the bead lock screw holes on the back side of my wheels. then if i know im going to play in the water i just put those screws back in and they are water tight again. Or i have have used silicone or liquid electrical tape to cover the holes for the time being
11-29-2010, 01:59 AM | #8 |
I just squeeze the tire out to get the water out, if Im really concerned about it, take the foam out of the tire, squeeze and let dry, its not really that bad or that big of a deal.
11-29-2010, 03:30 AM | #9 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
i like the beadlock screw idea but i'd do a couple on each side as theyre gonna be really small holes
11-29-2010, 04:59 AM | #10 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Buy some nova's!
11-29-2010, 07:02 AM | #11 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
The stock foams that come with the flat irons are basic at best. Believe me, the flat irons can work fine for you. Buying a softer rubber compound tire is one good way to do well. RC4WD's roc lox or pro line TSL swampers are a good upgrade. Rims is another, the stock Rims don't really allow a lot of flex, upgrade to an aluminum rim for more weight. And you will want a foam that has sidewalk support, but a soft center where the tires will grab most. Contact crawlers inovations. He is a vendor here.
11-29-2010, 07:43 AM | #12 |
Wow, thanks so much everyone!! Man there is so much to re-learn here. Things sure have changed in the last 20 years since I have my last truck! I will do some searching around and I definitely appreciate the information. |
11-29-2010, 06:01 PM | #13 |
RCC Addict Join Date: Jan 2004 Location: Gunbarrel
Also know that running the stock foams that come in RTR Honcho they are Proline memory foams. With the weather we have had here that last few days, the cold will make memory foam hard. The memory foam is ok in the summer, but in the winter they suck!
11-29-2010, 06:22 PM | #14 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
you can also add some weights to the rim ,thats alot of what your seeing in the standstill shots,that makes the tires look like the air pressure has been lowered for crawling
