12-19-2010, 07:10 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Duluth
| snow tires
I have done several searches and have found very little info on tires that work well in snow/ice. What are you guys useing? On a second note has anyone tried studding tires? If so what did you use and how well did it work? |
12-19-2010, 08:24 PM | #2 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
| I know IMEX Red Rocks work well in the snow. I would also think that Pitbull's would work in the snow due to them being so wide, I know they work good in the sand.
12-19-2010, 08:32 PM | #3 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
A lot of colorado guys made chains that have worked extremely well.
12-19-2010, 08:38 PM | #4 |
Driving on the snow/ice is too dangerous.
12-19-2010, 08:43 PM | #5 |
| I have a set of Flat Irons with chains, what I am looking for is a good set of 2.2's that will get me up on top of the snow. Something a little wider so I don't sink as much and that will give good traction and self clean.
12-19-2010, 08:56 PM | #6 |
Pebble Pounder Join Date: Sep 2009 Location: spearfish,sd
sedonas all the way |
12-19-2010, 09:11 PM | #7 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
UTRCRC had a scale comp yesterday and there was a lot of snow. The two tires that seemed to do well were RC4WD 1.9 Boggers with the small lugs cut out and the Proline 2.2 TSL's.
12-20-2010, 08:37 AM | #8 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
go with the pitbulls on a 1" rim. nice and wide, but lots of different contact patchs. cant wait for snow here in ct to try them.
12-20-2010, 08:41 AM | #9 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
I have a set of 2.2 Flat Irons that I hacked up that flat out work in the snow. They clean amazingly easily and have awesome bite! Ice is tuff with any tires, but snow is similar to mud, just need to clean the tread out to get some grip. Matt |
12-20-2010, 06:47 PM | #10 |
RCC Addict Join Date: Oct 2009 Location: Council Bluffs
i used pitbulls here and we had around 3-4inchs on the ground and they cleaned extremely well and the only times i got stuck was because i didnt have enough wheel speed to get up the drifts. otherwise they worked flawlessly
12-20-2010, 07:48 PM | #11 |
Pebble Pounder Join Date: Jun 2007 Location: PNW- Eugene.
| LMFAO. Go to your local hardware store, get a bunch of chain, like smaller diameter chain, scale size. and make your own! it shouldn't be too hard. Actually, not that you mentioned this, I'ma go make some of my own too. thanks! |
12-20-2010, 08:30 PM | #12 | |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
12-21-2010, 09:21 AM | #13 |
Pebble Pounder Join Date: Apr 2010 Location: Manitowoc
Somebody on one of the other threads was saying they use flat thumbtacks pushed through from the inside of the tire. That was for on ice I think it would help on hard packed snow and wouldn't hurt in other snow. Hope this helps.
12-21-2010, 03:50 PM | #14 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
| I did the thumb tacks back in the day and did oval racing on my pool when it froze over haha. Even better is when someone doesnt pay attention and grabs the truck by its tires. |
12-21-2010, 09:34 PM | #15 |
Pebble Pounder Join Date: Jan 2009 Location: Bucktown
tire chains are good for all around bashin but for snow i like to use, get this, A new bright tire off a hummer its 7" x 3.5" mounted on a 40 pro line one with chains bigger is better |
12-22-2010, 12:47 PM | #16 |
RCC Addict Join Date: Nov 2008 Location: Frederick
Rovers with stock foams. object width="853" height="505">http://www.youtube.com/v/F2OcMz3kaGQ...</param><param name="allowFullScreen" value="true"> OK why does it do this? Every time I try to embed a code it comes up like this. On you tube to go to embed the high light it and copy and paste then this shit comes up. Help please. Vid: http://www.youtube.com/watch?v=F2OcMz3kaGQ Last edited by Creepy Inc.; 12-22-2010 at 12:51 PM. |
12-22-2010, 12:59 PM | #17 | |
No Crawling at Cunningham Falls | |
