01-21-2011, 06:36 AM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Denver
| Trimming foam to fit wheel weights?
Got some new TSL swampers with foams in them, I would like to add a bunch of weight to the wheels. The last set of wheels and tires I added weight to, the foam seemed to fight me quit a bit. Do you guys trim your foam on the inside to get them to seat better? Seems with all the extra space the weights are taking up you should trim the foam a little. Any pics showing this would be great! Thanks |
01-21-2011, 11:20 AM | #2 |
RCC Addict Join Date: Feb 2006 Location: ccxc
i always just jammed the foam over it.....
01-21-2011, 11:26 AM | #3 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Yes, you should trim the foams. I use either a dremel with a sanding drum attachment or an air die grinder with a sanding drum attachment. It will make the foams perform properly and reduce the bounce from over stressed foams. |
01-21-2011, 11:31 AM | #4 |
Does anyone have any pics of this process?
01-21-2011, 12:01 PM | #5 |
hmm, since Nova chimed in I'll trim mine
01-21-2011, 07:28 PM | #6 |
ANyone have pics? Thanks |
01-21-2011, 10:04 PM | #7 |
Quarry Creeper Join Date: Sep 2008 Location: Rogue River
yes im also having this problem. pics would be great!
01-22-2011, 10:54 AM | #8 |
I use the plastic wire brush thingy that came with my dremel to notch the foams. Usually I just do two runs around the inside of the foam to cut the edges, spaced apart and just deep enough to let the weights fit. Then its just a matter of pinching the foam and tearing it free. Easy peasy. |
01-23-2011, 08:37 AM | #9 | |
Pics of this would be awesome | |
01-23-2011, 09:39 AM | #10 |
I cut the foams as-is. I'll see if I can get some pics for you later today. |
01-23-2011, 09:44 AM | #11 |
03-06-2011, 08:59 PM | #12 |
Newbie Join Date: Mar 2011 Location: wis
No pics yet??
03-06-2011, 09:46 PM | #13 |
03-08-2011, 07:03 PM | #14 |
Quarry Creeper Join Date: Jan 2011 Location: Hurricane
I layed my wheel with the weight on it on top of the foam marked it with a fine point marker and cut it out with a razor blade. I don't have any pictures of any of it but I don't really know what you would take a picture of anyways. The memory foams were alot harder to cut than the foam ones but if you take your time it works out good. I just wish they would hurry up with the dual stage units for the Claws.
03-08-2011, 09:34 PM | #15 |
I got pictures! Honestly! I'll get them up tonight, I promise!
03-08-2011, 09:49 PM | #16 |
Rock Stacker Join Date: Aug 2008 Location: tamworth, nsw, australia
I made myself a hot-wire cutter that sliced through foam like a ....hot knife through....butter?? I found myself needing to get some larger diameter foams and also found myself in a state of impatience and wanting another project, so I made the hot-wire cutter as a sort of lathe set-up. Used a power source box, some nichrome wire, various plumbing fittings for the arm, abs plastic board as a base to work from and started cutting. Used an old camping mattress that used memory foam as a sort of self-inflating set-up. Not the best stuff, just what I had lying around..... Admittedly it won't give the neatest finish, but it did the job for me. Got exactly the O.D I wanted, and by un-doing the wire, passing it through a small hole in the centre of the foam, I got to cut the I.D so I got a foam ring without having to glue any joins With all this in mind, I'm sure notching the foam to star-cut, add cut-outs around weights what-ever would be easy. Not neat and all professional like, just easy. |
03-08-2011, 09:55 PM | #17 |
Here's the dremel tool I use, its a plastic brush. And here is a foam that I grooved. I've done it on memory foam, Rover foam, Nova foam, and F400 foam. Works great. |
03-08-2011, 10:12 PM | #18 |
Thanks for the tips an thanks for the pics duuuuuuuuude. That now makes perfect sense. Thanks everyone. |
