Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Understanding VP hubs!
Old 02-13-2011, 10:21 PM   #1
Default Understanding VP hubs!
225 = 8.55, 350 = 8.80, 475 = 8.92, 600 = 9.05, 725 = 9.3
I copied those measurements directly from VP's site, I'm trying to measure up some widths because I'll be ordering a set of DH pro comps. All I'm wondering is if these measurements are mm. Pretty silly I know but I wasn't 100%
Sorry these were for the SLW, below is the pro comp II
Axial AX-10 Axle
335= 9.25
460= 9.50
585= 9.75
cagedcbr is offline   Reply With Quote
Old 02-13-2011, 10:29 PM   #2
That is in inches from outside of wheel to outside of wheel
Chaotic Crawlers is offline   Reply With Quote
Old 02-13-2011, 11:02 PM   #3
abadk9420's Avatar
For the DH2 Wheels up front you will want to wait and get the wider hub that should be coming out soon to give you more clearance, for the rear the with the SLW in the rear I would probably go with the 475 or 600 hub if that is what you are planing on doing, I have the same wheel set up on my AX10 and the 350 hubs make it a little to narrow for my liking.
abadk9420 is offline   Reply With Quote
