03-10-2011, 02:13 AM | #1 |
Rock Stacker Join Date: Mar 2011 Location: apple valley
| Wheel weights
I'm new to crawling and would like to know if there is a common set of wheel weights that ppl use that are not the weights for real cars. i have a losi night crawler and the center of my wheel is to small for the real wheel weights to cars.
03-10-2011, 02:57 AM | #2 |
Pebble Pounder Join Date: Jul 2009 Location: Sydney
Lead sheet. Should be able to buy it from your hardware. Cut it into strips and roll it onto your rim. Use a bit of tape to hold it in place. Alternatively you could buy some knuckle weights. |
03-10-2011, 03:00 AM | #3 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Read the post right below yours. Try a little at least.
03-10-2011, 08:26 AM | #4 |
Buy a big roll of solder and wrap it around your rim.
03-10-2011, 10:18 AM | #5 |
| CrawlinClodKiller The other post wasnt there when i was looking at first. his was bumpd up. i did not how ever look to many pages in. |
03-10-2011, 12:41 PM | #6 |
03-10-2011, 10:34 PM | #7 |
the solder for cooper seems nice..i read that if u go to a actual tire shop they have many kinds of weights..not just like two kinds like at harbor freight.
03-14-2011, 08:09 PM | #8 |
Pebble Pounder Join Date: Mar 2011 Location: Humboldt
You can get adhesive backed lead weights at just about any tire shop. They are usually separated into1/4 oz pieces so you can play around with different weights to tune your tire/wheel setup
03-15-2011, 02:00 PM | #9 |
Pebble Pounder Join Date: Dec 2010 Location: Midwest City
You can fit "real" wheel weights on the Losi wheels. Here's mine with 4 oz stick-ons bent in a circle and covered with electrical tape. I left a small gap to poke through the tape for the vent holes. |
03-15-2011, 03:47 PM | #10 |
Pebble Pounder Join Date: Feb 2010 Location: Calgary
I found a 1 pound roll of lead in the fishing section at walmart that works pretty good.
