04-19-2011, 02:29 PM | #1 |
Newbie Join Date: Feb 2011 Location: Sweden
| RC4WD Hummer wheel + proline tsl match????
Im having some very hard time mounting my proline super swampers on my rc4wd beadlock wheels they are not wery accomodating to me . Seems like the tire is to thick where it lies on the rim beacause the bolts arent long enough to pass thru the 3 pieces. Have anyone tried this setup and got it to work and maybe have some good tip for me, or should i just forget it and purchase a set of rock locks instead |
04-19-2011, 02:39 PM | #2 |
Rock Stacker Join Date: Feb 2011 Location: Umea, Sweden
Hi Erik! Figured it was going to be a problem mounting Prolines to those. You could try this method for mounting your tires: Link from RC4WD Or you could turn your tires inside out and cut the bead all the way around, but it'll probably going to be a p.i.t.a. to cut them straight enough. /Jimmy Last edited by Stuntman Jim; 04-19-2011 at 02:43 PM. |
04-19-2011, 06:10 PM | #3 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
The RC4WD Military (Hummer) beadlocks in 1.9 actually hold Prolines without a problem. The wife runs Flatties on her Compscale truck, and I have had them on and off the rims a few times playing with foams, etc... However, to get the screws to reach, I had to make a jig with large washers and a screw/nut to clamp the wheel together to get the nuts started. Last edited by Badmuthatrucker; 04-19-2011 at 06:28 PM. |
04-20-2011, 07:50 AM | #4 |
thank u Badmuthatrucker the jig worked like a charm |
04-20-2011, 08:10 AM | #5 |
No problems |
