06-17-2011, 01:02 PM | #1 |
Rock Crawler Join Date: Mar 2011 Location: USA
| hex hole axial wheel rounded out repair????
Is ther any way to repair the hex hole in a wheel after it has ran loose and rounded out ,Axial nylon wheel ,,I bought these used and the hex hole was rouded out ,,,Thank you ,,,KMS |
06-17-2011, 01:05 PM | #2 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
Mill, lathe, or route it off, bolt on Vanquish hubs.
06-17-2011, 01:43 PM | #3 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Glue/epoxy the drive hex into the wheel. Downfall is you can loose the drive pin when removing wheels, but hey, you didn't have to buy a new wheel.
06-17-2011, 07:44 PM | #4 |
Thank you ,,I will set them aside for awhile ,,have another set so will use them..KMS
06-18-2011, 01:39 PM | #5 |
06-19-2011, 01:06 PM | #6 |
I stripped out a stock AX-10 wheel and JB-Welded a plastic hex into it. Worked good for a few more monthes, then the drive pin ate through the plastic hex. If'n you JB-Welded an aluminum hex into the wheel it would probably be as good as new. |
06-22-2011, 12:17 PM | #7 |
Newbie Join Date: Nov 2010 Location: new england
Wrap a hex with plumbers teflon tape, then JB weld the hole and stick the hex into it. When it dries you can remove the hex and it will be almost as good as new.
06-22-2011, 12:36 PM | #8 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
I superglued mine in. been working for a year. I like zim35 idea. |
