07-21-2011, 01:07 AM | #1 |
Quarry Creeper Join Date: May 2011 Location: Australia
| double deuces foam
i just recieved my foams from crawler innovations and they are in some rovers and i notice that they are a little hard what should i do? should i run them till they unstiffen or is it always going to be stiff
07-21-2011, 07:42 AM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: meriden
run them, dd are great foams and very tunable but u need to buy a couple diff out side density like a med and soft with med inners and maybe some tuner rings. u wont be disappointed |
07-21-2011, 07:51 AM | #3 |
Fist off, what kind of truck is it, how much does it weigh, what tires are you running and how wide are your wheels?
07-21-2011, 09:29 AM | #4 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
Are your wheels vented? They are great foams but like said above, every rig is different and likes different things so a bit of tuning to get them just right is all thats needed. Matt |
07-21-2011, 10:30 AM | #5 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
First of all, THANK YOU for your purchase and post New foams are going to be a little stiff and even bouncy until they break in. I recommend running at least 5 - 8 battery packs to break in the foams before tuning them. Never put in brand new foams and head out to a competition. I did that once and it cost me. The foams were bouncy and wouldn't stay on point / line. The foams definitely soften a little as they break in. I recommend venting your wheel, not the tire. Three 1/8 air holes drilled into your wheel is plenty. I also recommend, leaving the foams in the tires once you have them tuned for your crawler. Water is a foams worst enemy. It will soften, stretch, and break down the tire foams quickly. If you can keep them dry, they should last a season easily. A few questions that will help me give you advice, What is the width of the wheels you are using? How much does the crawler weigh RTR? Are the rovers stock or modified-siped-grooved? Which combination foams did you purchase? |
07-21-2011, 03:17 PM | #6 |
hey fellas im currently waiting on Mayhem double patty rims so im not sure how much the truck weighs the truck is a losi comp crawler and the rims im getting are 1inch the rovers are stock foamRear: firm inner and med outer frount:outer:medium inner , mem outer (how do i know which are frount and rear) another thing is i with have to put holes in the tire cause the rims im getting arn't vented and i dont wanna go for a swim again the stuffed my other foams |
07-21-2011, 03:38 PM | #7 |
Drill holes in the wheels if they didnt come that way. Im with Nova, I dont care for vented tires. If you get into water with them just be sure to squeeze it all out before you put it up. I mark my fronts tires on the inside with a small silver sharpie dot to remember which is which, I also usually have them heavier than the back which makes it easier to tell as well. Matt |
07-21-2011, 08:48 PM | #8 | |
