09-30-2011, 12:08 AM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: Santa Rosa
| Beadlock ring anodizing????
So I have these rings that used to be red but now they are pink due to the sun I guess, I was hoping maybe someone knew a trick to remove the anodizing back to the raw aluminum. I tried oven degreaser and it took it off alittle but not all the way. Any suggestions would be great. Thanks
09-30-2011, 12:36 AM | #2 | |
Quarry Creeper Join Date: Oct 2010 Location: NOR-CAL
I use Oven Off in the yellow can.Then I use Mothers aluminum polish because i like the shiny polished look. Quote:
09-30-2011, 12:47 AM | #3 |
09-30-2011, 12:50 AM | #4 |
09-30-2011, 01:11 AM | #5 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Just don't leave it on too long it will pit the aluminum. I keep getting sidetracked when I do this and it makes it a lot more work to clean.
09-30-2011, 08:24 AM | #6 |
Grease Lightning. Let the rings soak for about an hour and they will be bare aluminum. I just did some Axial green a little while ago. It worked great.
09-30-2011, 09:19 AM | #7 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
The media blast cabinet here at work made short work of the anodizing on my rings. |
10-04-2011, 10:46 AM | #8 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
10-04-2011, 04:06 PM | #9 |
Newbie Join Date: Mar 2011 Location: defiance
i use the wire wheel in my dremel till color is gone then shine them up it works great
10-05-2011, 11:38 AM | #10 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Easy off in the yellow can then aluminum polish. Oh it helps if you hit the rings with a toothbrush right before rinsing the oven cleaner off. It seems to make it easier to polish them in less time if you do that.
