Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: skinny 2.2 tiers
Old 11-08-2011, 05:49 AM   #1
Default skinny 2.2 tiers
What are the skinniest tiers in 2.2 cheers
mrbowbow is offline   Reply With Quote
Old 11-08-2011, 07:11 AM   #2
tiers???
well you can cut and shut any 2.2 tire...and get them down to about 1/2"
ROSS is offline   Reply With Quote
Old 11-08-2011, 07:31 AM   #3
These are pretty narrow. Not the best all around crawling tire but work decent if you sand down the internal ribbing on the inside and don't run alot of foam in them. I like them for the looks and they do perform grippy rocks and the mud/bashing terrain.
Interco Super Swamper 2.2 TSL/Bogger Scale Tire
On the JK.
http://www.rccrawler.com/forum/g-mad...e-doors-6.html
Szczerba is offline   Reply With Quote
Old 11-08-2011, 07:32 AM   #4
For stock 2.2 tires, likely Rovers or Cougars.
I believe there is a thread with various tires listed & the dimensions.
Running a narrow rims helps as well.
Why do you want to know??
Charlie-III is offline   Reply With Quote
Old 11-08-2011, 07:49 PM   #5
Im just looking for a more scale looking 2.2
Old 11-08-2011, 09:22 PM   #6
Proline super swampers
Axial ripsaws
RC4WD Rok Lox
All are a pretty narrow tire that when mounted on a narrow wheel around one inch wide will look pretty scale. Or you can try to cut and shut a set like others have said.
BLKXJ 96 is offline   Reply With Quote
Old 11-08-2011, 10:09 PM   #7
I dont think I would be able to cut and shut a set
Old 11-09-2011, 05:52 PM   #8
Ya, gluing a tire back together seems like a really unreasonable amount of effort
troyd is offline   Reply With Quote
Old 11-09-2011, 05:59 PM   #9
You could try some rc4wd rock and die tires. They are really narrow and work pretty well.
Hittman is offline   Reply With Quote
Old 11-09-2011, 09:14 PM   #10
More so I wouldnt have the fine touch, attention to detail and patients to do it
Old 11-10-2011, 05:10 PM   #11
i think a cut-n-shut would be your best choice. just had these made for me, definitely worth it. you would be very pleased with a 1.9
joeyf is offline   Reply With Quote
Old 11-10-2011, 08:37 PM   #12
no talent hack
What's the height on those?
Nabil is offline   Reply With Quote
Old 11-10-2011, 09:57 PM   #13
right at 5"
Old 11-10-2011, 10:44 PM   #14
Wht glue do they use to do it
