11-24-2011, 12:27 PM | #1 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
| stiffer sidewalls?
i have a set of exceed mad torque tires. i ditched the stock foam and cut the lugs so they work very well. the tires are super soft and grip good so i dont wanna change the foam to much, i just need to stiffen the sidewalls a bit. the tires lean a bit to much on the sideways stuff. New tires are NOT an option. any tips and tricks would be very appreciated
11-24-2011, 12:46 PM | #2 | |
Quarry Creeper Join Date: Mar 2009 Location: moses lake wa
11-24-2011, 12:49 PM | #3 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Use a set of sidewalls and ca them to the inside.
11-24-2011, 12:55 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Dual stage foams from CI. Firm inner and med to soft outer not sure on your tire ht so check before ordering. He has 3 hts IIR corretly |
11-24-2011, 01:51 PM | #5 |
11-24-2011, 01:53 PM | #6 |
11-24-2011, 01:53 PM | #7 |
11-24-2011, 01:56 PM | #8 |
i just want something thats permanent. duct tape doesnt seem permanent. I dont know but il try it.
11-24-2011, 10:15 PM | #9 |
Pebble Pounder Join Date: Jan 2011 Location: Red Hill, Pa
Crawler Inovations makes foam "tuning disks" that fit inside the tire and stiffen the sidewalls a little. I've never used them but they're cheap, or you could make your own with a thin sheet of foam from the hobby or craft store. CI link -- Lil' Nova 1.9 Tuning Disc Pair (2) |
11-25-2011, 09:47 PM | #10 |
i would have to make my own because my rim alone is bigger that that piece of foam but that is a good idea. i coyld make them out of the stiff stock foam that i got left
11-25-2011, 10:06 PM | #11 | |
Quarry Creeper Join Date: Dec 2009 Location: Grass Valley Ca
Tags |
exceed, sidewalls, stiffen, tires |
