Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: tire foams
Old 10-15-2012, 05:27 PM   #1
Default tire foams
whats the best foams to use with the rover tires on a XR10? and wheres the best place to buy them?
traxxasemaxxer is offline   Reply With Quote
Old 10-15-2012, 05:48 PM   #2
Default Re: tire foams
I'd say get some crawler innovations use link here 5.25T Double Deuce Pair (2)
mammoth is offline   Reply With Quote
Old 10-15-2012, 07:51 PM   #3
heres the speck on the rims Im using I guess I should go with the wide inner width?
Old 10-15-2012, 09:09 PM   #4
Probaly want 5.5 ci foams instead of 5.25. 5.25 is from what i know for boss claws, thats what i run. Rovers are taller by 1/4 inch. Whats the weight of your rig? Thats gonna be deciding factor for starting point on foam from crawler innovations. Good luck
Sheepdawg23wm is offline   Reply With Quote
Old 10-16-2012, 07:24 PM   #5
I tried the stock rover foam,losi claws foam,double Duce and the proline two stage. I think the deuce worked better on rock but were to soft and pinched my tires to much in the woods. I stuck with the prolines.
xCoolHandLukex is offline   Reply With Quote
tire foams - Similar Threads
tire foams robo-3 Tires and Wheels 5 12-20-2006 01:12 PM
Tire foams: Yes or No? fullmodtxt Tires and Wheels 6 07-06-2004 11:41 PM
