03-03-2013, 11:32 AM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: Waterford , PA.
| Venting aluminum wheels ??
How are you guys venting your aluminum wheel/tire combo's ? Whats the best option ? Thanks
03-03-2013, 11:33 AM | #2 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
| Re: Venting aluminum wheels ??
A drill with a 1/8 bit has always worked for me.
03-03-2013, 12:02 PM | #3 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
I usually drill two holes per wheel then tap them out to 4mm so I can plug the holes with 4mm set screws if I'm going to be running in wet conditions.
03-04-2013, 08:25 PM | #4 |
Thanks guys.
03-05-2013, 02:40 AM | #5 |
I've punched three holes in the side of each tire instead. The main reason is that I use closed cell inner foams, so holes in the rim would be useless. |
03-08-2013, 01:59 PM | #6 |
Pebble Pounder Join Date: Mar 2010 Location: Morristown TN
| Re: Venting aluminum wheels ?? |
03-10-2013, 06:44 AM | #7 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
| Re: Venting aluminum wheels ?? Here are how I vent my comp wheels |
Venting aluminum wheels ?? - Similar Threads | ||||
Venting: Wheels or tires? | zjguy721 | Tires and Wheels | 6 | 03-14-2011 08:39 AM |
Venting Wheels?????? | redcatguy | Axial XR10 | 17 | 09-17-2010 01:30 PM |
Venting Vanquish LH 1.9 Wheels!!! | renoirbud | Tires and Wheels | 1 | 05-24-2009 06:19 PM |
Tire Venting vs. Wheel Venting | kawika | Tires and Wheels | 2 | 07-08-2007 09:29 PM |
