03-16-2013, 03:33 PM | #1 |
Pebble Pounder Join Date: Nov 2012 Location: on the edge!
| plastic 2.2 wheels with zero backset?
hey guys (and gals), does anyone know if anyone makes a 2.2 wheel in plastic or delrin that has hubs that are flush (no back set)? I'm looking for a set of light rims my buddy can use with his P4de. He used my Mayham rims and they fit I have a .75 hub on them. does anybody know of something similar in a light weight material either plastic or delrin? thanks for any and all help |
03-16-2013, 04:03 PM | #2 |
Pebble Pounder Join Date: Jul 2007 Location: Oveido, Florida
| Re: plastic 2.2 wheels with zero backset?
stock axial ax10 rims
03-16-2013, 05:49 PM | #3 |
| Re: plastic 2.2 wheels with zero backset? yeah? I'll check them out thanks! Are they different from my Ridgecrest rims, cuz they won't work hub isn't out far enough.
03-16-2013, 06:17 PM | #4 |
they are diffrent then ridgecrest rims
03-16-2013, 08:05 PM | #5 |
I assume you are talking about the AX10 Scorpion rims? Am I correct , the Ridgecrest is also a AX10
03-16-2013, 08:08 PM | #6 |
looking on ebay brings up lots of different rims I'll check Axial website
03-17-2013, 12:14 AM | #7 |
Yes i am talkin bout the old school ax10
03-17-2013, 05:55 AM | #8 |
thanks man! Those look like they might just work!
03-17-2013, 06:55 AM | #9 |
been looking but I can't actually find a definitive answer to what the backset is on those wheels, who can help?
03-17-2013, 10:37 AM | #10 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I think this is what you are looking for. SP452 Tamiya Stadium Blitzer Rear Wheels 1 Pair | eBay Although I do have a couple sets of the old delrin beadlocks that have the hex flush to the inside. a |
03-17-2013, 12:11 PM | #11 |
ahhh S^*T Join Date: Mar 2012 Location: in the shop bending metal in Whatcom Co. WA.
there are plenty of wheels that will work. the axial 8 holes are close, rocksters, tamiya wheels warpig spoke of but non beadlock. also a good one is Venom Creeper wheels. very stout wheels. or look for some mayhem delrin comp solids?/ I think.. look the same as warpigs rig above as far as offset goes.. the new so called "AX10" is the ridgecrest and are the same wheels as the wraith, they have a very deep hex. positive offset. you can narrow xr10 wheels, ax10 wheels and PL wheels to have even more offset. I might not know what Im talking about just going from my experience |
03-17-2013, 05:17 PM | #12 |
no luck with any of these yet, the hub needs to be flush or proud of the edge of the rim (on the backside). nothing seems to work.
03-17-2013, 07:17 PM | #13 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Losi LCC wheels. I am able to run high steer knuckles with them. Sent from my Desire HD using Tapatalk 2 |
03-17-2013, 08:10 PM | #14 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
LCC rims sounds like they would work great. They are almost flush I'd give them a shot.
03-17-2013, 08:48 PM | #15 |
Tamiya Wild Dagger wheels are what you want. I just found a set of the white wagon wheels and they are offset. The Wild Dagger are flush on the inside. Wild Dagger: Beadlocks: |
03-18-2013, 06:16 AM | #16 | |
| Re: plastic 2.2 wheels with zero backset? Quote:
Thanks for your help | |
03-18-2013, 06:20 AM | #17 | |
Thanks for your help you are very knowledgeable, thanks | |
03-18-2013, 08:25 AM | #18 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
The older MSD wheels with TLT offset are also the backset you are looking for. PM me if you like I believe I have a set I would part with. I will have to double check....
03-18-2013, 08:35 AM | #19 |
RPM Revolver (Wide Crawler Wheel). RPM "Revolver" Wide Base Crawler Wheels (Black) (2) [RPM82232] | RC Cars & Trucks - A Main Hobbies I run them on my Slash 4x4 with 2.2 PitBulls. |
03-18-2013, 10:32 AM | #20 |
Johnnyh, that is what Jang (ultimate rc)said would work. do you have any sort of hub extenders on your rig? nice looking rig! |
plastic 2.2 wheels with zero backset? - Similar Threads | ||||
Will plastic wheels last? | ErÄjOrMa | RC4WD Bully | 7 | 03-16-2010 05:56 PM |
What's up with the $5 plastic wheels? | MtnBkr | Tires and Wheels | 67 | 08-06-2009 08:52 PM |
plastic 2.2 wheels? | NeXt559 | Tires and Wheels | 6 | 11-25-2008 10:13 AM |
