![]() | #1 |
Pebble Pounder Join Date: Mar 2008 Location: Happy Valley
I'm looking for very positive offset 1.9(or even 1.55) wheels, hopefully beadlock. I know this topic has been covered many times in the past but.... ![]() ![]() Last edited by Sul; 04-03-2013 at 07:08 PM. Reason: Brain fart.. |
![]() | #2 |
Quarry Creeper Join Date: Jul 2008 Location: lansing
if you are looking for a more narrow track width you will want positive offset wheels.
![]() | #3 |
![]() | #4 |
0mm HPI shock car wheels are the most backspacing/+ offset out there. but they are plastic nonbeadlock wheels. ::HPI RACING:: or you could go to a comp beadlock wheel DLUX 2.2 AND 1.9 wheels Last edited by STANG KILLA SS; 04-03-2013 at 07:41 PM. |
![]() | #5 | |
| ![]() Quote:
![]() | #6 |
Ok, so I figured out how I got the positive/ negative offset thing backwards in my head before I started this thread. I was looking at wheels on SDI's site right before posting this. They have their +1 offset wheels with deepest dish and their -5 wheels with the mounting surface closest to th outer bead. So their +1's pushing the tire out and their -5's pulling the tire in. I don't know maybe they are referring to back spacing as offset... And again if there are any other ideas out there I'm open ![]() |
![]() | #7 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
They are not beadlocks.... But all touring car wheels are 1.9's.... They all run a very positive offset and a lot of them come in different offsets.... There are tons of t/c wheels out there in all types of flavors.
![]() | #8 | |
| ![]() Quote:
![]() typically touring car (and SDI) wheels are giving in they usually start at 0mm and go +3, +6, +9 etc. the larger the number the wider your track(in mm per side) and the deep dish the wheel. you would want the -5 for the narrowest track. dont forget about the clearance issues this may cause. links, shocks etc. | |
![]() | #9 |
| ![]() Yes, I know they aren't bead lock but I'm trying to keep my options open. They do have a good look though. I might just be back to the old days of gluing tires.
![]() | #10 | |
| ![]() Quote:
So if I'm understanding what your saying; T/C wheels and in turn SDI wheels don't use standard offset measurents? It appears what they're using is more of a backspacing type measurement..? Thanks for the input. | |
![]() | #11 |
you can also run Axial narrow hubs. Axial Narrow Aluminum Hub, Black, 12mm, 4pc |
![]() | #12 | |
| ![]() Quote:
Max negative offset 2.2 wheel? | CREEPERBOB | Tires and Wheels | 12 | 12-17-2012 12:09 AM |
looking to widen my stance without wideners want a wheel with all negative offset | gasser55t | Tires and Wheels | 21 | 09-24-2011 05:08 PM |
Negative offset wheels | TSK | Tires and Wheels | 5 | 02-12-2009 10:47 AM |
Negative offset beadlocks, | Magic | Newbie General | 5 | 10-29-2007 11:36 AM |
what 2.2 rims have the most negative offset? | dankycrawler | Tires and Wheels | 24 | 05-24-2007 04:02 PM |
