How should I setup scale Wraith Vanquish blue foam with yellow white black inserts?
I have a Wraith with 2.2 Venom Ridge Line tires with the axial 8 hole wheels and the Vanquish blue foams and the 3 other sets of inserts. I'm not sure how to set them up. I'm running a pretty heavy setup. I run allot on compact dirt with allot of side hill and tight turns. We hit the rocks some times too. I'm wondering how I should set these up. Right now I was thinking of cutting the inserts up and putting a black part in the middle and two yellow pieces on each side on the back and white in the middle with blue on the outsides for the front for a little softer side wall, but I'm not sure if I should do that in every slot or do every other slot and leave the others with the blue inserts or a harder one. If anyone has been threw this and could help me out and keep me from taking my wheels apart a bunch of time I would REALLY appreciate it! Thanks.
