Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Proline 2 stage Memory Foams Questions.
Old 07-30-2014, 04:24 PM   #1
Default Proline 2 stage Memory Foams Questions.
Does anybody know if the inner and outter foam rings are glued together and if not, do you think those will fit on a set of Proline's short course wheels?
I'm in the planning stages if a Telluride trail rig and plan on using the Proline ProTrac/SC10/Losi SCT beadlocks with M3 compound Trencher SC tires, but the standard foams are too stiff. At first, I figured on just going old school and star cutting the foams, then discovered HPI offers their SCT foams in soft, but those are back ordered right now. I was even thinking about using DuBro's 1/2" thick foam cusioning sheets. I then remembered the above mentioned foams and noticed that the outter rings look like they might be useable and even thought that e-mailing Proline and asking if the above question might be a good idea.....................
They told me that the stock SCT foams will be stiffer than the memory foams.............
BJoe is offline   Reply With Quote
Old 08-03-2014, 02:36 AM   #2
Default Re: Proline 2 stage Memory Foams Questions.
Got access to 4 wheel mod buggy foams? I run the fronts as inners and stadium truck fronts as outers. Costs about $9 for a set of four
This is for a 1.9 btw. Not sure what combo would work on a 2.2
djjiz is offline   Reply With Quote
Old 08-03-2014, 03:06 AM   #3
Thanks!
I have been debating about just ordering these just to see if they will work. If they do, fantastic! If not, I'll see if there's a way to make them work with the 1.9" Swampers with the aid of touring car foams.
Old 08-03-2014, 03:27 AM   #4
wrightcs77 gave me a 55 gallon bag full of memory foams back in the day and they were a bitch to tune. Too hot = too soft and too cold = too hard. They would feel good in the morning but by mid afternoon they would fold over and I eventually gave them away.
Old 08-03-2014, 05:38 AM   #5
I'vd also got that set of HPI foams still on order too, just to try. Kinda unchatrd territory here, just don't have the funds to play with here like I used too.
Old 08-03-2014, 05:54 AM   #6
If you are short on funds I would not mess around and just get some Lil' Novas from Crawler Innovations. Send a email to Eddie and he'll get you lined up.
realsickclown is offline   Reply With Quote
Old 08-03-2014, 06:02 AM   #7
i have the foams they are glued together but there perfect size for pits i think. thats the only tire i use them in and they do great.
gunder463 is offline   Reply With Quote
Old 08-06-2014, 01:37 PM   #8
Looks like the HPI SCTfoams are off back order now, so hopefully those will be in soon. I work at the hobby shop so the discount is very nice on that kind of stuff.
Old 08-06-2014, 04:09 PM   #9
Same here
Proline 2 stage Memory Foams Questions. - Similar Threads
Go from Losi "Rock Claws" w/ memory foams to HB "Rovers" (pink) w/ Proline Dual Stage luvmycompax10 Tires and Wheels 4 01-11-2012 04:13 PM
proline memory foams questions,problems 929freak Tires and Wheels 4 12-13-2008 11:29 AM
