Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: Rc4WD 2.2" Steel wheels/swamper irok question
Old 09-17-2014, 12:19 PM   #1
Default Rc4WD 2.2" Steel wheels/swamper irok question
I have 2.2" steel rc4wd black stock style wheels. They are the three piece ones that the inner and outer of the rim sandwich the tire and then hub goes on and the nuts/bolts go around the center. I have irok 2.2 mounted on them. My problem is when they get squishe down from driving they don't come back up again. They still all flat and squished until I pull apart the whole wheel again. What can I do?
Nev072708 is offline   Reply With Quote
Old 09-17-2014, 02:52 PM   #2
Sand/file down the bead surfaces of the inner and outer wheel halves to provide some grip for the bead of the tire. What's happening is that one side has spun from its original location.
What's better than that are the discontinued CHUD steelie spacers. They allow the steelies to grip any tire.
Meatwad is offline   Reply With Quote
Old 09-17-2014, 08:01 PM   #3
Default Re: Rc4WD 2.2" Steel wheels/swamper irok question
So my objective is to keep them slightly sealed instead of putting holes to let it in/out? I was wondering if I should be putting vent holes in the wheel or tires somewhere but was trying to avoid it.
Old 09-21-2014, 05:21 PM   #4
Vent the tires!!! It will let the tire perform much better!!!! Either way hole in rims or tires still let water in but the foams will dry! Which to me it's a no brainer to vent tires!!!
sic1to is offline   Reply With Quote
Old 12-11-2014, 07:41 PM   #5
Interesting. I have the same wheels with 2.2 Mudslingers on them now and am about to switch to a set of Iroks. I've never had the problem you mentioned with the Slingers and one of the things I've really liked about these wheels is how well they seal and keep water out. I've contemplated venting the tires but hate all the gunk getting inside the tires and wrecking the foams.
Selser420 is offline   Reply With Quote
Rc4WD 2.2" Steel wheels/swamper irok question - Similar Threads
Anyone have rc4wd oem steel wheels with interco IROK tires? Siccmade Tires and Wheels 14 05-01-2012 08:15 AM
Anyone have rc4wd oem steel wheels with interco IROK tires? Siccmade Axial SCX-10 0 05-05-2011 08:28 PM
