12-06-2014, 09:25 AM | #1 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
| locked up rc wheels questions,
so i want to order a set but im so lost on what hardware i need to order from them i want the scale hardware in zinc but how much of what ones do i need there so vague on the sight and they dont tell if the wheels are easy mount or not and im just lost.
12-06-2014, 09:35 AM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: locked up rc wheels questions,
All of LURC's are Easy Mounts now, I think Patrick converted everything over when he changed the beadlock bolt pattern. For their wheels, you'll need to purchase the M2x7mm Zinc scale hardware and a bag of M2x1mm (85). To install the scale hardware, you'll also need to purchase the 2mm Hex Socket driver. When installing those M2x1mm faux screws, I highly suggest you take the extra time and rethread the threads with the supplied M2 nuts. It will make your life much easier and it will keep for the threads stripping out in the beadlock ring. Last edited by Lentsnh2012; 12-06-2014 at 09:38 AM. |
12-06-2014, 09:41 AM | #3 |
Don't waste your time with the 2x1mm faux screws. They SUCK. Just get multiple bags of the regular bead lock scale bolts. That's the whole point of the easy mount wheels.
12-06-2014, 09:41 AM | #4 | |
| Re: locked up rc wheels questions, Quote:
12-06-2014, 09:46 AM | #5 | |
Just do some easy math to calculate how many bags you need to buy of the M2x7mm scale hardware. 1 30 pack will take care of the main bead setting screws, then there is a set of 3 for every one mounting screw. | |
12-06-2014, 11:22 AM | #6 | |
12-06-2014, 12:28 PM | #7 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Why not contact Patrick ( locked up rc) thru is store or via a pm on here ? He is extremly helpful and does is very best to make the consumer happy. Tell him what wheels you want and he will tell you what and how much hardware to get. They are so detail and customer driven, he even has a note on the top of the website to let all know he will be at an event untill 12/8... and orders will ship on the 9th.... Communication is number1 in customer service |
12-06-2014, 02:06 PM | #8 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
"If you do not have a set of our Easy Mount wheels you can use 18 of our M2x1 "faux" screws to thread into the ring. You can also use any M2 hardware (scale hex bolt or cap head) of your choice and shorten the screws to be flush with the back of the ring once threaded into it. Either way will allow you to mount the ring to several different brands of wheels. The ring still mounts to the wheel with only 6 screws (don't cut these!), making your life much easier when working with foams and weights. " Simple math for the scale hardware on the face of the wheel, 18+6=24 screws per wheel when using the LockedUp beadlock rings . So if you buy 4 wheels with 4 rings you'll need a grand total of 96 screws. (this was figured using the 1.9 wheel with Inspired rings) 18 of the screws will be for looks while the other 6 will actually mount the rings to the wheels. Last edited by Hoosierdady; 12-06-2014 at 02:09 PM. |
12-06-2014, 02:25 PM | #9 | |
locked up rc wheels questions, - Similar Threads | ||||
Which SLW Hubs For Locked Up Wheels? | Dirty 'Yota | Axial Wraith | 7 | 09-04-2014 02:18 PM |
New wheels from Locked Up RC | sgtsteve | Tires and Wheels | 4 | 04-09-2012 10:35 AM |
