01-04-2015, 03:05 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: richmond
| best u4rc beadlocks
I have been running pro line titus headlocks and i keep running the tires of the wheels. what would be the best bang for my buck i priced out the slw vanquish with hubs and rims I'm at 150. is there anything else out there that would be cheaper but still do the job? thanks |
01-04-2015, 03:26 PM | #2 |
| Re: best u4rc beadlocks
Crawler innovations 6 bolt glue ons will hold your tires and are the cheapest option out there.
01-04-2015, 04:44 PM | #3 |
| Re: best u4rc beadlocks |
01-04-2015, 05:15 PM | #4 |
RCC Addict Join Date: May 2011 Location: at home
saw some delrin beadlocks being offered by rc4wd at a decent price Rocker 2.2 Lightweight Competition Beadlock Wheels also check out the dlux wheels, they look pretty good. another option is to look in the rcc classifieds. there are some good deals to be found there. |
01-04-2015, 05:39 PM | #5 |
01-04-2015, 05:51 PM | #6 |
01-04-2015, 07:11 PM | #7 |
Quarry Creeper Join Date: Sep 2012 Location: Seattle, wa
I went with the glue option myself. You can always bake the tire off. I know its a bit of a pain but its most cost effective at $25 for a set of wheels plus slw hubs. I wanted to use a beadlock wheel myself but most are heavy and the lite ones are a minimum $150. Carterfab does a nice delrin method glue up wheel.
01-05-2015, 10:33 AM | #8 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
i know the gear head derlin wheels are nice and hold a good bead. idk bout those rc4wd ones its still 130$ before shipping. but as everyone is saying the CI 6bolts are the way to go,
01-05-2015, 10:45 AM | #9 |
01-05-2015, 11:06 AM | #10 |
Moderator Join Date: Jan 2004 Location: chicago
i use either a thin or medium tire-specific ca glue on my wheels. youtube some tire gluing videos before you take it on, its relatively easy but you dont wanna bork it up. my advice is to really really clean your wheels and tires before gluing to get rid of all the mold releasing agents and stuff that keeps the glue from sticking. |
01-05-2015, 12:41 PM | #11 |
thanks to yall sugestions i found a set ci 6 bolts. also ordered foams, hubs, and glue.
01-05-2015, 07:51 PM | #12 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Vanquish Products FTW!
01-05-2015, 09:44 PM | #13 |
01-07-2015, 06:40 AM | #14 |
01-07-2015, 07:25 AM | #15 |
Newbie Join Date: Jan 2015 Location: Boston
I think im gonna try the CI Six Bolt also, because they are sooo cheap and look good with the Voodoos
01-07-2015, 04:38 PM | #16 |
| Re: best u4rc beadlocks i have 3 bent V5's and 2 bent V2's so i just gave up they actually are bent where the hub goes on its like the spokes twisted, ive tried to fix them a couple times and it just dont work.
01-07-2015, 04:46 PM | #17 | |
| Re: best u4rc beadlocks Quote:
The V3's have held up well for me. Then again, there is a good bit more spoke to them.. 4s powered 3500kv HD in the Sexo And 4s powered 3000kv HD in the Yeti | |
01-07-2015, 04:53 PM | #18 |
Quarry Creeper Join Date: Sep 2009 Location: Las Vegas
^ That's all the endorsement I'd ever need, if winnerone23 didn't break them, they aren't going to break |
01-07-2015, 05:05 PM | #19 |
| Re: best u4rc beadlocks well maby ill try those then just havent had any luck with them but you are right they do have quite a bit more spoke to them, honestly the v5's i wasnt suprised seeing as how the spoke is flat and not very thick. and im not nessisarily breaking them they still work they just wobble something awful,
01-07-2015, 05:08 PM | #20 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
I used Losi tire glue for a couple buggy sets just before Xmas, that glue is outstanding compared to others I've used in the past. I pretty much always use standard, some manufacturers thin, can be very difficult to work with. Another trick for removing tires from glued wheels, put them in the freezer for a day or two, when you remove them, push the bead with your thumb around the wheel, and it usually just cracks free. I had a set of HPI wheels and tires years ago where this method did not work, I had to use heat for them.
best u4rc beadlocks - Similar Threads | ||||
norcal u4rc | VP Dan | U4RC | 29 | 06-23-2014 12:17 AM |
U4rc set up help | sanny632 | U4RC | 2 | 05-23-2014 08:08 PM |
U4rc @ rcx | ZoSo | U4RC | 3 | 05-21-2014 07:04 AM |
U4rc | BoulderDan | Arizona | 3 | 11-24-2013 10:51 AM |
