03-02-2016, 02:06 PM | #1 |
Pebble Pounder Join Date: Apr 2015 Location: Charleston
| Wheel and Tire Size.
So I bought Pro-Line 1.9 Super Swampers with Axial 8 hole beadlocks. The tires were a nightmare to get on. After doing some research is seems as though the wheels are 1" wide and the tires say 1.75". Did I make a rookie mistake and actually buy a mismatched set? Sent from my iPhone using Tapatalk |
03-02-2016, 04:24 PM | #2 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Wheel and Tire Size.
Proline tires have a funky shaped bead that works fine in Proline's wheels but they can be a pain to mount in some other wheels. The gigantic oversized foams that they come with make them hard to mount as well. |
03-02-2016, 04:32 PM | #3 |
Quarry Creeper Join Date: Aug 2013 Location: Bullard TX
I ran the Proline Super Swamper TSX XL on Axial wheels for a while. I used Crawler Innovations foams and they were pretty simple to install. They are narrower on the inside so they don't push against the bead as much when you're trying to mount them.
03-02-2016, 04:46 PM | #4 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
The key thing here is patience. I got frustrated, but kept trimming away since I really wanted to use the Axial 9-hole beadlocks. Eventually I wound up destroying the entire bead. The fix? Had to buy another set of XLs. The second time around I threw in the towel and purchased Proline beadlock wheels. I guess the silver lining is that I now have a single XL that I can mount up as a spare. |
Wheel and Tire Size. - Similar Threads | ||||
4 wheel drive tire size differences | gfmucci | Newbie General | 8 | 04-21-2015 02:56 AM |
The difference in wheel & tire size | blacksmith | Newbie General | 4 | 11-25-2008 11:17 AM |
TXT-1 wheel adaptors and tire/wheel combo ?? | markja | Tires and Wheels | 2 | 12-22-2006 05:08 AM |
Nylint Crawler Tire Wheel Size Specs | 911rc | General Crawlers | 2 | 08-21-2005 09:54 PM |
