06-26-2016, 10:03 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Norway
| RC4WD Scrambler Offroad 1.9" Scale Tires
Specification: - Advanced X2SS Compound (Super Soft & Super Sticky) - Fits 1.9" Wheels - OD: 4.09in / 104mm - ID: 1.81in / 46mm - Width: 1.69in / 43mm - Each Tire Weight: 1.96oz / 55.6g - Source: RC4WD Could not find and info on here about these tires. Anyone tryed them? Looks perfect for class1. Am deciding between these, Genius sem limites, and Growlers 1.55 for class 1. |
07-01-2016, 07:24 AM | #2 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
| Re: RC4WD Scrambler Offroad 1.9" Scale Tires
Another Max Trep but this one is short enough to fit under the rc4wd Blazer body. Sweet!
07-01-2016, 12:49 PM | #3 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Looks like a mix of KLR and Trepador and a good size for the RC4WD Blazer body. I may have to give them a try.
07-03-2016, 10:08 AM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
I just got a set waiting on a shipment of GCM wheels to mount up. As you guys probably know, the X2SS compound is excellent. In person, tread pattern and depth look comparable to the 4.19" Baja Claw, so I expect performance will be similar to that tire. Performance should also be similar to the 1.7 Iroks (4.1" OD). With most of the X2SS tires (notable exception being the Kryptons), I typically find the stock foams a bit soft and end up switching over to CI foams. Deuce's Wild 4.25-4.19" single stage foams work well on these smaller C1 tires, esp. on heavier hard-bodied scale rigs. They leave a little bit of room between foam and tread, which gives nice compliance, while having plenty of support to prevent folding over. Once I get some run time in with the tires, I'll post up some pix & reactions.
07-03-2016, 11:11 AM | #5 |
Looking forward to hear some more about these. Looks quite interesting. Not decided yet if I will go for this, growler or genius sem limites for my class 1.
07-24-2016, 07:33 PM | #6 |
Anyone running these yet?
RC4WD Scrambler Offroad 1.9" Scale Tires - Similar Threads | ||||
Scale Offroad presents - Rough Ryders "The Back 40" ~HD~ | limited77 | Scale Videos! | 6 | 03-30-2011 10:15 AM |
