07-06-2016, 11:01 PM | #1 |
Newbie Join Date: May 2016 Location: Scotch Plains
| Proline 1.9 TSL XL
I purchased a set of 1.9 TSL XL tires and would like to ask for advice on which CI foams I should buy. The tires are going on a newly built stock SCX10 2 that I will use primarily for crawling on rock courses. I noticed CI has a single stage closed cell foam specifically for the 1.9 TSL XL but i would think this is to stiff for rock crawling. Would a 2 stage foam like the little nova be better for this purpose? If so what size and firmness would suit these tires best. Thanks for the help! |
07-07-2016, 11:07 AM | #2 |
| Re: Proline 1.9 TSL XL
CI has a single stage closed cell foam specifically for the 1.9 TSL XL, fits great and works great, I love em! |
07-07-2016, 11:24 AM | #3 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
I'm using the two stage and think they work very well. Can't say anything about the single stage as I have never used them.
07-07-2016, 11:43 AM | #4 |
| Re: Proline 1.9 TSL XL |
07-07-2016, 11:48 AM | #5 |
I don't remember, I think so but I would e-mail C.I. they will be glad to tell you. I did softs in the front and med in the rear. |
07-07-2016, 01:53 PM | #6 | |
Pebble Pounder Join Date: Jun 2012 Location: Lucerne Valley
| Re: Proline 1.9 TSL XL Quote:
This is how I set up my Swamper XL's, 4.50 med. in the front and 4.75 firm in the back. I had the single stage in them before and I feel this set up works better. | |
07-08-2016, 06:51 AM | #7 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
I did ci lil'nova 4.50 med front, firm rear. Happy with that for a truck not too happy. I also have a set with tsl xl deuce wild, which I like more. Sent from my SM-G930F using Tapatalk |
07-08-2016, 05:46 PM | #8 |
| Re: Proline 1.9 TSL XL Thanks for the input. You did not feel that the deuces wild molded foam inserts were to stiff? I am putting these on a SCX10 2 that is fairly light and i am concerned that a stiff foam will not let the tire conform on the rocks.
07-08-2016, 06:04 PM | #9 | |
I see your point with the light rig, but I think it's more important to consider what style of driving you like. If mostly hardcore crawling, then go two stage. If any variation at all, then definitely go deuces wild. Those are my thoughts, just edit: with the tsl sx xl tires in particular the matching deuces wild work great. These tires have a very aggressive pattern, and the foam gives them some freedom of movement also. That's my experience. Sent from my Nexus 10 using Tapatalk Last edited by tjohanne; 07-08-2016 at 06:20 PM. | |
07-08-2016, 06:21 PM | #10 | ||
And vent the tires as per CI's site recommendations, not the wheels. | ||
07-08-2016, 07:13 PM | #11 | |
